OK . . . I have the "New Adjustment Layer Button" at the base of the Layers Window. It is there - no problem . . . But I want to have it at the TOP of the Layers Window where I have other Layer Commands, and I wish to have the "New Adjustment Layer Button" there too.
Please advise,
Grazie
New Adjustment Layer Button? Want to reposition it?
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: New Adjustment Layer Button? Want to reposition it?
Open up the Customize dialog
View -> Customize
Then on the layers palette, click on the "New Adjustment Layer" button and drag it to the top of the Layers palette. Keep in mind the Layers Palette seems to have two sides. If you over-fill one side it'll overlap with the other unless the layers palette is wide enough. So, make sure you have room.
View -> Customize
Grazie
- motherboard: Asus TUF X299 MK 2
- processor: Intel Core i9 10900X s2066
- ram: 64gb
- Video Card: EVGA RTX 3080 XC3 Ultra 10GB
Ah! I was attempting to do what I had previously done, and that was to ADD a button directly from the Customize >>Command, I had forgotten to just DRAG the New Adjustment Layer Button North to the top of the Layers Palette.LeviFiction wrote:Then on the layers palette, click on the "New Adjustment Layer" button and drag it to the top of the Layers palette.
Thank you!
Grazie
