lata wrote:Hi
Can you provide the full properties of the problem video file, right click the clip in the timeline and select properties, what are they?
You could create an image of the window and attach to your post.
You can render the video to use Upper field or Lower field to create an interlaced video, whether that will cure the jagged edges is to be seen, my first thoughts are that it may not help as the jagged edges are embedded within the progressive video.
Anyway the best option is to use Settings Movie Profile Manager to create a new template, using the Add option will create a template using your video files properties, first choose your video format (I assume AVCH264) then browse for your file.
Edit the template changing only the Frame Type from the General tab : choose Upper Field rather than Frame Based
By the way what does it indicate as the frame type before changing anything.
The template will be available from Share – Avch.264 –profile options.
As I say it may not work, maybe the interlacing used earlier is lower field, besides how is Video Studio gonna recognise the interlacing within a progressive file??????
Haha That's what I was saying!
The file itself is progressive, so I don't know whether they were doing some Telecining that didn't take (the clip is 25fps but NTSC not PAL/SECAM) or was doing it on purpose, but there is clearly interlacing/lines showing in a 480p video...
Thanks for the idea of changing the output, I was experimenting a bit with that, re-rendering it in Fields and seeing if any players deinterlaced it 'properly'. I might try re-importing the UFF or BFF re-render back into VSP and see if it detects the interlacing and 'takes it out' along with the actual now-interlaced file...interlacing when it processes it. This feels like dealing with Time Travel - kinda fun
The file itself comes up as Frame Based in VSP. Here is the full Mediainfo metadata:
General
Format : MPEG-PS
File size : 23.1 MiB
Duration : 1mn 22s
Overall bit rate mode : Variable
Overall bit rate : 2 366 Kbps
Writing library : encoded by TMPGEnc (ver. 2.58.44.152)
Video
Format : MPEG Video
Format version : Version 1
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=18
Duration : 1mn 22s
Bit rate mode : Variable
Bit rate : 2 127 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.277
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
Stream size : 20.8 MiB (90%)
Source encoded stream size : encoded by TMPGEnc (ver. 2.58.44.152)
Writing library : TMPGEnc 2.58.44.152
Audio
Format : MPEG Audio
Format profile : Layer 2
Duration : 1mn 22s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 1.88 MiB (8%)
So, it's not AVC, they used simple MPEG with a PAL frame rate and NTSC frame resolution (which is why I thought maybe they were trying some Telecining and it didn't take).
Thank you for all the workaround ideas. I was looking for an actual Deinterlace FX/filter or something that could be 'forced' to process the video, but I didn't see it. To answer your question, the only video editing application that I know of off the top of my head that can actually 'detect' interlacing in a progressive file is Nero Video (they use motion detection and something else I can't remember, but I assume it would also process things like bare branches on trees in winter as interlacing, but I haven't tested that assumption). I usually used other little Freeware editors to force deinterlacing (like Virtualdub or Avidemux), but was seeing if there was a way to 'do it all' in VSP.
Neat little problem anyway, I'll have fun messing with it for a while
