How to create leather background, stitch, and emboss effect?
Corel Newbie
- Corel programs: Paint Shop Pro 2023
One of the things I find most frustrating using PaintShop Pro (any version) is learning how to do a new type of effect. The main reason being is a combination of; incorrect keyword phrase and/or search term I used for desired effect, and/or the publish solution does not contain the same keyword phrase and/or search term for desired effect I used. The other reason, when I do find a published solution its usually for significantly older versions of PaintShop Pro -which discourages me from upgrading, in fact its the main reason why I don't upgrade until several versions later. So I will use a link to a visual example in case the I did not use the correct term.
Anyway, I wish to create my own leather background, with stitching, and emboss (here is an example http://www.istockphoto.com/stock-illust ... st=f7b80e3).
Thanking you in advance for your patience.
Joelle
- motherboard: Asus Prime B350M-A
- processor: AMD Ryzen 5 1500 Quad-Core
- ram: 16 GB RAM
- Video Card: NVidia GeForce GTX 1050
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung
- Corel programs: PaintShop Pro X9
Re: How to create leather background, stitch, and emboss eff
It's tricky to get the correct search terms.Corel Newbie wrote:One of the things I find most frustrating using PaintShop Pro (any version) is learning how to do a new type of effect. The main reason being is a combination of; incorrect keyword phrase and/or search term I used for desired effect, and/or the publish solution does not contain the same keyword phrase and/or search term for desired effect I used. The other reason, when I do find a published solution its usually for significantly older versions of PaintShop Pro -which discourages me from upgrading, in fact its the main reason why I don't upgrade until several versions later. So I will use a link to a visual example in case the I did not use the correct term.
But "PaintShop Pro tutorials" is always a good start
I have had a try at leather stitching and this is what I have come up with.
To make the leather:
Fill an new image with the colour of the leather>Effects>Texture Effects>Fine Leather.
Experiment with the settings if you don't like the default.
For the stitching:
I have used an oblong with rounded edges on a transparent background and exported that as a Picture Tube.
File>Export>Picture Tube.
For the settings, see attached.
New Raster Layer, then start on the left and hold the Shift key to make a straight line of stitching.
If you are not familiar with the Layers Palette, the Help Files are there to help
Have fun
Joëlle You need to remove the white background: Right-click on the layer and select Promote Background Layer. Then select the white with the Magic Wand and hit Delete.
Then Export it as a Picture tube as described above. PS: Suz Shooks' place is a good site to find interesting Hints and Tips, plus scripts:
http://suzsplace.com/
Searching for PSP Scrapbooking sites should be helpful finding stitching.
Joëlle
(PSPX9 )
(PSPX9 )
photodrawken
- ram: 16Gb
- Hard_Drive_Capacity: 324Gb
Joelle,
That stitching looks really good. Add a little embossing to the stiches, and a sunken layer shadow and you'll really have something....
Ken
Joelle
- ram: 16 GB RAM
Thanks Ken
I tried to keep it as simple as possible, the extra bits can be added later
Joëlle
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
photodrawken
- ram: 16Gb
Chicken.Joelle wrote:...the extra bits can be added later
Ken
Joelle
- ram: 16 GB RAM
It's the NEWBIE part of the name that made me think that information was enough to start with
Joëlle
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
photodrawken
- ram: 16Gb
Yeah, I knew I'd have to put up or shut up....
So, here's my attempt: I never used Picture Tubes before, so it was a good learning experience. I see how they can be very useful.
PSP's layer styles leave a lot to be desired, but at a small scale the effect sort of works.
Ken
Joelle
- ram: 16 GB RAM
Very nice, well done.
Layer Styles are not the best, but sometimes the Reflection setting is useful.
I always duplicate the layer if I am adding a Layer Style effect.
Picture Tubes are great fun and very handy.
I don't use the ones that come with PSP much, but have made many of my own over the years. The folder was getting a tad big, have culled a few..
Joëlle
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
photodrawken
- ram: 16Gb
Joelle,
By the way, I think I created the stitch picture tube in a slightly different way than you did.
For the OP, my steps were these:
- Use the rectangle Preset Shape tool. First set the "Horizontal Radius" and "Vertical Radius" (in the Properties bar) to 10.
- Draw out a stitch so you get a nice shape.
- Rotate the shape slightly if you want.
- Apply a background colour and a texture background pattern (using the Materials Palette).
- With that entire vector group (containing the stitch) selected, use Edit...Copy. This eliminates any background -- the background comes in as transparent.
- Then use Edit...Paste As New Image to get only the stitch in the new image.
- Right-click on the vector layer (in the Layers Palette) and choose "Convert to Raster Layer".
- Use File...Export...Picture Tube to create the picture tube.
Ken
Corel Newbie
Thank you all.
I was trying to create a background seamless texture image to be used on a new website as the background for global horizontal navigation bar, the brown leather strap with stitching portion was the effect perfect I was looking for.
I have already purchased the rights to use the image, would it better/easier to just select a sampling slice from said image and try to create a horizontal seamless textured tile? I have already tried, but there was nothing seamless with my failed end results?
Welcome any suggestions.
Thanks again!
Frustrated PaintShop Pro X6 Newbiew User
Thanks again!
photodrawken
- ram: 16Gb
Just copy your slice to the Clipboard and then paste it in as a new image. Then use Effects...Image Effects...Seamless Tiling.Corel Newbie wrote: I have already purchased the rights to use the image, would it better/easier to just select a sampling slice from said image and try to create a horizontal seamless textured tile? I have already tried, but there was nothing seamless with my failed end results?![]()
Ken
Corel Newbie
Tried it, but it did not come out seamless.
