DVD Compression problem
Biotech
Post by Biotech »
Got DVD movieFactory 3se with my ADS DVD Express, liked it so much that I purchased version 4.
I have been transfering home movies using the mentionned hardware/software setup. The problem I am running into is if i use the shrink to fit feature. All DVD's created using this feature will not play in my home DVD player.
For example the same file burned onto a Dual Layer disk works fine but if I use a 4.7GB disk it will not play on the home player but works on the computer DVD player.
I have used DVD Shrink in the past for that purpose with the same disk and everything worked fine.
Are there any settings in the software that I need to tweak to make the compressed copies play properly?
Thank you in advance for your help,
Biotech
