How to image skew via node editing?
DaveG74
Post by DaveG74 »
Is there a way to skew an image/shape via node editing rather than entering numbers in fields? (For example, skewing a rectangle by moving nodes around on the corners?)
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: How to image skew via node editing?
Post by LeviFiction »
The pick tool has a skew transform mode, well it's labeled Shear but it's the same thing. A perspective transform mode. And a Free transform mode.
With these modes you can distort your image by dragging the corners and middle nodes.
magnoliasouth
processor: Intel[R] Core[TM] i5-9300H CPU
ram: 8 GB
Video Card: Intel UHD Graphics 630
sound_card: Conexant SmartAudio HD
Hard_Drive_Capacity: 881 GB
Monitor/Display Make & Model: Generic PnP Monitor
Corel programs: PSP 2021, et al
Post by magnoliasouth »
LeviFiction wrote:The pick tool has a skew transform mode, well it's labeled Shear but it's the same thing.
I knew I wasn't going crazy. Would you believe that is now gone in 2020? Mine no longer has that option. :(
See profile data for system information.
magnoliasouth
ram: 8 GB
Grundberg wrote:Is there a way to skew an image/shape via node editing rather than entering numbers in fields? (For example, skewing a rectangle by moving nodes around on the corners?)
First, you don't have which version you are using in your control panel. This question is most easily answered if you would share which version you are using with us. Go here ucp.php?i=172 and it should open your User Control Panel and have the Profile Tab selected. Scroll down to the very bottom and where it says Corel Programs list which programs and versions you have from Corel.
That said, in PSP 2020 I can only find a single (and PIA) way to do this, if you're using a shape. If you want rounded corners, then you can just drag the top left node to the right and it'll work easy peasy. However, if you want to skew it, I cannot find an easier way than this (yet).
  1. Draw out your rectangle and make sure its layer is selected.
  2. Go to Objects > Convert to path
  3. Select the Pen tool and make sure it's in Edit Mode on the tool ribbon.
  4. Select the nodes you wish to edit.
  5. Now go back to Objects > Transform selected nodes > Select either Skew X or Skew Y.
  6. Finally, click on the nodes and drag them however you wish.
Note: You'll probably need to play with a bit to get it right the first time.
I hope this helps other PSP 2020 users with the same problem and if you know of a better way, please post.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
I have PSP 2020 and drew a rectangle with the Shape tool and then was able to choose the Pick tool and even though it does not have the choices of Shear etc as mentioned by Levifiction , the shortcut keys worked - Hold down the Control and Shift keys and then a corner and you can move that node / point alone to make weird shapes from the rectangle.
migf1
operating_system: Windows 8.1
Post by migf1 »
hartpaul wrote:I have PSP 2020 and drew a rectangle with the Shape tool and then was able to choose the Pick tool and even though it does not have the choices of Shear etc as mentioned by Levifiction , the shortcut keys worked - Hold down the Control and Shift keys and then a corner and you can move that node / point alone to make weird shapes from the rectangle.
Same here, shortcuts work
Good Unofficial PaintShop Pro Tutorials: Creation CasselMake Shop ProHEC Image EditingLeviFiction PSP Basics
(plus my own Gimp & Stuff)
