Remove Background from Video VS X6
I recorded some video of a person speaking. I do not like the background and would like to remove it so I can add another one. I tried using the Chromakey feature and various filters for VideoStudio but was not able to completely remove the background.
Any help you can provide for a novice is appreciated.
Best Regards
Best Regards
Re: Remove Background from Video VS X6
Could you describe the current background? Chroma Key will only remove a background which is a solid colour. If your background is anything else, such as a scene with object or people in it, then there is little you can do except re-film with the background you are after.
Thanks for the quick reply. The background the person was standing in front of was a chain link fence. I will not be able to get the person to reshoot it. Would I have to shoot a new video with a solid background and then combine them?
Hello,
Can you let me know if you have any additional information on this topic?
Your never going to be able to change the background completely - your best option would be to make a mask with a transparent "hole" in the middle as near to the shape of the person talking as possible - put the picture you want as the background on the mask
I have made up a sample mask which is in the zipped file below - download and unzip it and put it in the overlay track - now I do not know your speaker image size - so you will have to make your own to fit your speaker image and I do not know what image you want instead so I have just used a bright coloured background which could be any image or picture you choose - but I hope the image below gives you an idea of what you can do
Troy at TheGTAMblog
- motherboard: Gigabyte 970A-DS3P
- processor: Intel i3-8300
- Video Card: NVIDIA GTX 1060
- sound_card: Creative Labs Tactic Alpha 3D THX Certified
- Hard_Drive_Capacity: 11TB total
- Monitor/Display Make & Model: Dell 2407WFP
- Corel programs: PaintShopPro, VideoStudio
If I may pop in with a related query, is there a way to create a mask in VSP? As in, 'draw' a shape around an object, saving that to be utilized as the mask?
No unfortunately that is not possible - I make all mine in another image manipulation programme and import them into VideoStudio - given time you could take a still image from a video frame - take that into whatever image manipulation package you prefer and make a cut out frame there to take back into VideoStudio.
The real answer of course is to shoot against a plain background and Chroma key it out in Videostudio then you can change your background at will.
digifigi
- motherboard: HP 1965 KBC Version 93.52
- processor: 2.40 Gigahertz Intel Core i7-4700MQ
- Video Card: Intel HD Graphics 4600 17.1
- sound_card: IDT HD Audio codec
- Hard_Drive_Capacity: 999GB
- Monitor/Display Make & Model: Generic PnP Monitor 17.1"
I have a similar problem. Your suggestions above helped a lot. I'm using VSP X6. Unfortunately, I filmed in Black and White so I can't use the Chroma Key to eliminate the background. I did Take Snapshots, and edited the photo to create masks. However, the area I want to see is four men in a row who are singing and moving.
Here is a link to the unlisted video still rough cut on youtube: http://youtu.be/xmyYCC3-H54 How do I get the mask to move with the men? The only other solution I see is to slice the video, take snapshots and create more masks.
Pam Ronan aka digifigi
ah yes you have a real problem there as the four men are not moving in unison - I cannot think of an easy way to do it - unless someone else has an idea your cutting and multiple masks may be the only answer.
digifigi
Thanks, hopefully someone will have a bright idea before I start snipping and trimming. I have a month before the complete project is due (9 reproduction commercials and intros and outros).
