White Balance Issue: Tint = 150
Bugs & Suggestions
UnderDriven
operating_system: Windows 8.1
Post by UnderDriven »
I was a Bibble user, and I switched to ASP when it came out. The first few versions were fine, but when I downloaded an update about 6 months ago I noticed some strange behavior in the White Balance section. Images displayed "As Shot" have a tint value of 150 (max). If I manually set the value to something "reasonable" the colors are way off. I didn't want to deal with the problem at the time, so I went back to the old version. Now I have migrated to Windows 8, and I have no choice but to use the current version. I was hoping this issue would be fixed by now, but I'm seeing the same behavior with the version I just downloaded. Clearly, the tint value should not be at the maximum to display a normal image. Does anyone have an idea what is going on?
lenscape
operating_system: Linux
System_Drive: N/A
motherboard: Multiple
processor: Multiple
ram: Varies
Video Card: nVidia Corporation generally
sound_card: Varies
Hard_Drive_Capacity: 15TB+
Monitor/Display Make & Model: Multiple
Corel programs: Aftershot Pro 2
Re: White Balance Issue: Tint = 150
Post by lenscape »
UnderDriven
lenscape wrote:This is a duplicate issue:
http://forum.corel.com/EN/viewtopic.php?f=94&t=51151
Thanks. I assumed I wasn't the only one with the problem. Unfortunately, there doesn't appear to be a solution. Luckily I kept the download file for a previous version which works...
