Ubuntu 14.04 TRUSTY Tahr: Aftershot Pro NOT INSTALLABLE
ubuntuuser
- System_Drive: N/A
After reading http://ubuntuforums.org/showthread.php?t=2183444 I found out, that ia32-libs was removed since Ubuntu 13.10 (a developer version), which is needed by Aftershot Pro. Therefore Aftershot Pro cannot be installed with Ubuntu 14.04 Trusty Tahr, the latest LTS-Version of Ubuntu.
Does anyone know, when a new ASP-version can be expected, which works with Trusty? Does Corel know this? They should have acted sind 13.10 is out.
Re: Ubuntu 14.04 TRUSTY Tahr: Aftershot Pro NOT INSTALLABLE
hello,
try this :
http://forum.corel.com/EN/viewtopic.php ... 19#p280519
it's works on a Debian Jessie,
ge_ka
try this :
ge_ka
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Do not install the pseudo 64bit version but the 32bit version. Works here.
cheers
afx
cheers
afx
Kneops
- System_Drive: N/A
- motherboard: ASUS P8 Z68
- processor: Intel i7 2600
- Video Card: nVidia 450
- sound_card: onboard
- Hard_Drive_Capacity: 14 TB
- Monitor/Display Make & Model: Dell U2713H & Spider4
- Corel programs: ASP3
As I'm going to be a new user/client of AS, I hope the new version will be able to run on 64 Linux. At this moment I'm running a trial version from within Wine, because that runs better than the native version.
afx
- System_Drive: N/A
What runs better in Wine?
Curious...
cheers
afx
Curious...
cheers
afx
Grechary
- System_Drive: N/A
- motherboard: LENOVO 2349KAG
- processor: Intel Core i7-3520M CPU 2.90GHz
- Video Card: Intel Ivybridge Mobile
- sound_card: 7 Series C210 Series Chipset Family High Definitio
- Hard_Drive_Capacity: 580GB
- Monitor/Display Make & Model: GF108M [NVS 5400M]
Since release 13.10, Ubuntu doesnt support anymore the package ia32-libs.
On the other hand, Corel doesn't integrate this change : AfterShot is always looking for this package.
Here is a solution to set up AfterShot on Ubuntu 13.10 and 14.04.
Take in consideration, it is always better to use the Ubuntu Long Term Support release (like Ubuntu 12.04 or 14.04).
Anyway, to set up AfterShot we will add a former repository which includes ia32-libs.
But It is not recommanded to use a former repository. So after the installation, don't forget to unselect this repository.
You will start the followings commands into the terminal, with administration password.
# creat working directory
mkdir ~/tmp-AFS
cd ~/tmp-AFS
sudo -i
apt-get -f install
# c'est parti !
add-apt-repository -y "deb http://archive.ubuntu.com/ubuntu/ precise main restricted universe multiverse"
apt-get update
apt-get -y install ia32-libs
# get AfterShot and then install it
wget http://www.corel.com/.../Patches/1_1/Af ... _amd64.deb
sudo dpkg -i AfterShotPro_amd64.deb
Now you should unselect the old repository :
=> run the Update application
=> select Others sources ('Autres logiciels' in french)
=> search, find and unselect Precise repositories
That's all ! Have fun !!
mkdir ~/tmp-AFS
cd ~/tmp-AFS
sudo -i
apt-get -f install
# c'est parti !
apt-get update
afx
- System_Drive: N/A
Why bother installing the 64bit package?
AS is 32bit anyway.
So just install the 32bit package now that 64bit Ubuntu no longer needs silly workarounds.
cheers
afx
AS is 32bit anyway.
cheers
afx
afx wrote:Why bother installing the 64bit package?
AS is 32bit anyway.
cheers
afx
Funny that you post that now that they released real 64 bit binaries
afx
- System_Drive: N/A
I posted that before the release.txoni wrote:Funny that you post that now that they released real 64 bit binariesafx wrote:Why bother installing the 64bit package?
AS is 32bit anyway.
And there is still no good reason to use the 64bit version.
cheers
afx
rag2
- motherboard: Acer Revo
- processor: Intel Core i3-2377M
- ram: 4GB
- Video Card: Intel Sandybridge Mobile
- sound_card: V-DACII
- Hard_Drive_Capacity: 742GB
- Monitor/Display Make & Model: Samsung BX2331
Ah, but there is. Specifically, 64 bit OSes allow one to use more than 4GB of memory. With ASP2 allowing images up to 250Mpixels, that's about 1GB for 3 colour channels plus an alpha, or 2GB for 16bit channel depth. It won't be long before 4GB of RAM gets used up with complex processing!afx wrote:And there is still no good reason to use the 64bit version.
In an installation with more than one machine, there are sound reasons for moving as many installations as possible to 64 bit.
YMMV, of course!
josephlin
- Alludo
- motherboard: Intel Z490 chipset
- processor: Intel Core i9-10900K
- ram: 32GB
- Video Card: nVidia RTX 2070S
- sound_card: Realtek ALC892
- Hard_Drive_Capacity: SSD 1TB
Hi There, I assume here the ASP version that you are talking about should be ASP1 amd64.deb version, right? Actually ASP2 amd64.deb version already remove ia32.lib of independency thus this kind of issue should not happen with 13.10 or newer version again. Here is another solution can help you to install ASP1 amd64.deb version into Ubuntu 13.10 or newer version. Just for your reference.
https://bugs.launchpad.net/ubuntu/+sour ... ug/1241327 Ubuntu removed it.
Here is our solution, we did it in Ubuntu 13.10 Desktop version:
1. download "AfterShotPro_amd64.deb to "Downloads" folder.
2. Launch "Files" (file organizer), find "Downloads" folder and the file you just download.
3. Right click on "AfterShotPro_amd64.deb", choose "Extract here". You should find a new folder named as "AfterShotPro_amd64"
4. Click into "AfterShotPro_amd64\DEBIAN" folder, you can find a file "control"
5. edit this file with any text editor.
6. In this "control" file, you should find somethings like
Depends: ........ ia32-libs
7. remove ia32-libs from this file. and save it.
8. rename "AfterShotPro_amd64.deb" to a new name.
9. open a terminal
10. in terminal, change current folder to "Downloads", then enter command "dpkg -b AfterShotPro_amd64". Wait for a while, you will get a new AfterShotPro_amd64.deb
11. install AftershotPro with this new deb file. Ubuntu 13.10 will complain the quality of this package is not good, continue to install.
12 .in case Ubuntu still complains about dependency error. in step 7, try to remove everything in Depends section (that is from "Depends:" to the end of "ia32-libs"). then follow all other steps.
that is because those are not available in repository. Also, in this case, users may need to install those dependency package manually. that is for those libraries listed in "Depends" (except ia32-libs), you needs to run "sudo apt-get install [library-name]"
9. open a terminal
Cheers
Joseph Lin
Sr. Program Manager,
Corel PaintShop Pro / AfterShot Pro / VideoStudio
cascagrossa
- motherboard: Dell Vostro 3510
- processor: intel core I5
- ram: 4GB
- Video Card: Nvidia 310M
- Hard_Drive_Capacity: 500GB
- Monitor/Display Make & Model: Dell Vostro 15.6pol - 1366x768
This was tested Kubuntu 14:04 - 64 bits, fresh install and up to date.
After a lot off research, I came to a procedure that works without the need for radical changes:
1. The Go Synaptics and install "lib32z1" package,
2. At the terminal go to the "/ lib32" folder
3. Execute "sudo ln-s / usr/lib32/libz1.so.1.2.8 libz.so.1"
4. Execute "sudo ln-s / usr/lib32/libz1.so.1.2.8 libz.so.1.2.8"
5. At the terminal go to the folder where you dowloaded AfterShot 64bit.
6. Execute "dpkg -i AfterShotPro2_2.0.0.133_amd64.deb".
All done! ASP will install and run smoothly ...
buntu
- System_Drive: N/A
- motherboard: Asrock
- processor: X270
- Video Card: GF210
- sound_card: SBx00 Azalia
- Hard_Drive_Capacity: 5GB
- Monitor/Display Make & Model: Viewsonic, HP
I fail to install the 32bit package with Ubuntu Trusty. What can I do? I don't want to buy ASP again because of this, if I cannot get i work, I will change to http://www.darktable.org/
Code: Select all
cat /etc/issue
Ubuntu 14.04.1 LTS \n \lCode: Select all
# dpkg -i aftershotpro2_2.0.0.133_i386.deb
Vormals nicht ausgewähltes Paket aftershotpro2 wird gewählt.
(Lese Datenbank ... 415237 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von aftershotpro2_2.0.0.133_i386.deb ...
Entpacken von aftershotpro2 (174:2.0.0.133) ...
dpkg: Abhängigkeitsprobleme verhindern Konfiguration von aftershotpro2:
aftershotpro2 hängt ab von libc6.
aftershotpro2 hängt ab von libxcursor1.
aftershotpro2 hängt ab von libxext6.
aftershotpro2 hängt ab von libxau6.
aftershotpro2 hängt ab von libxdmcp6.
aftershotpro2 hängt ab von libxrender1.
aftershotpro2 hängt ab von libxrandr2.
aftershotpro2 hängt ab von libfreetype6.
aftershotpro2 hängt ab von libfontconfig1.
aftershotpro2 hängt ab von libexpat1.
aftershotpro2 hängt ab von libz1.
aftershotpro2 hängt ab von libpng12-0.
aftershotpro2 hängt ab von libsm6.
aftershotpro2 hängt ab von libice6.
aftershotpro2 hängt ab von libxi6.
aftershotpro2 hängt ab von libglib2.0-0.
aftershotpro2 hängt ab von libgcc1.
aftershotpro2 hängt ab von zlib1g.
aftershotpro2 hängt ab von libgl1-mesa-glx.
aftershotpro2 hängt ab von libglu1-mesa.
dpkg: Fehler beim Bearbeiten des Paketes aftershotpro2 (--install):
Abhängigkeitsprobleme - verbleibt unkonfiguriert
Trigger für shared-mime-info (1.2-0ubuntu3) werden verarbeitet ...
Unknown media type in type 'all/all'
Unknown media type in type 'all/allfiles'
Unknown media type in type 'uri/mms'
Unknown media type in type 'uri/mmst'
Unknown media type in type 'uri/mmsu'
Unknown media type in type 'uri/pnm'
Unknown media type in type 'uri/rtspt'
Unknown media type in type 'uri/rtspu'
Trigger für gnome-menus (3.10.1-0ubuntu2) werden verarbeitet ...
Trigger für desktop-file-utils (0.22-1ubuntu1) werden verarbeitet ...
Trigger für mime-support (3.54ubuntu1) werden verarbeitet ...
Fehler traten auf beim Bearbeiten von:
aftershotpro2I use Aftershot with http://xubuntu.org/
buntu
- System_Drive: N/A
- processor: X270
- Video Card: GF210
I don't understand what you mean with the "/ lib32" folder? What do you mean with the blank after /cascagrossa wrote:This was tested Kubuntu 14:04 - 64 bits, fresh install and up to date.
I tried this following your advice:
Code: Select all
dpkg -l | grep lib32z1
ii lib32z1 1:1.2.8.dfsg-1ubuntu1 amd64 compression library - 32 bit runtime
ii lib32z1-dev 1:1.2.8.dfsg-1ubuntu1 amd64 compression library - 32 bit developmentCode: Select all
ls -la /lib32/libz*
lrwxrwxrwx 1 root root 24 Jul 27 16:19 /lib32/libz.so.1 -> /usr/lib32/libz.so.1.2.8
lrwxrwxrwx 1 root root 24 Jul 27 16:19 /lib32/libz.so.1.2.8 -> /usr/lib32/libz.so.1.2.8Code: Select all
dpkg -P aftershotpro2Code: Select all
aftershot_pro_update_1.2.0.7# dpkg -i aftershotpro_amd64.deb
Vormals nicht ausgewähltes Paket aftershotpro wird gewählt.
Vorbereitung zum Entpacken von aftershotpro_amd64.deb ...
Entpacken von aftershotpro (174:1.2.0.7) ...
dpkg: Abhängigkeitsprobleme verhindern Konfiguration von aftershotpro:
aftershotpro hängt ab von ia32-libs; aber:
Paket ia32-libs ist nicht installiert.
dpkg: Fehler beim Bearbeiten des Paketes aftershotpro (--install):
aftershotpro
buntu
- System_Drive: N/A
- processor: X270
- Video Card: GF210
This was my 3rd attempt:josephlin wrote:Hi There, I assume here the ASP version that you are talking about should be ASP1 amd64.deb version, right? Actually ASP2 amd64.deb version already remove ia32.lib of independency thus this kind of issue should not happen with 13.10 or newer version again. Here is another solution can help you to install ASP1 amd64.deb version into Ubuntu 13.10 or newer version. Just for your reference.![]()
9. open a terminal
My 1st problem with this suggestion was that it was extracted with lower letters, so I had to rename it to AfterShotPro_amd64
Then I removed my previous installation:
Code: Select all
dpkg -P aftershotproAfterShotPro_amd64/DEBIAN/control
Code: Select all
Package: aftershotpro
Version: 174:1.2.0.7
Section: graphics
Priority: optional
Architecture: amd64
Essential: no
Depends: libc6, libxcursor1, libxext6, libxau6, libxdmcp6, libxrender1, libxrandr2, libfreetype6, libfontconfig1, libexpat1, libz1, libpng12-0, libsm6, libice6, libxi6, libglib2.0-0, libgcc1, zlib1g, libgl1-mesa-glx, libglu1-mesa
Pre-Depends:
Recommends:
Breaks:
Suggests:
Installed-Size: 130904
Maintainer: Corel Corporation <support@corel.com>
Provides:
Description: Corel AfterShot Pro
Get professional quality, quickly and easily. Manage and edit all of your digital photographs in Corel AfterShot Pro with amazing speed in a workflow tuned to your working style, with power and editing control offered in no other application.I didn't see any errors during installation:
Code: Select all
dpkg -i AfterShotPro_amd64_trusty.deb
Vorbereitung zum Entpacken von AfterShotPro_amd64_trusty.deb ...
aftershotpro (174:1.2.0.7) wird eingerichtet ...
Trigger für mime-support (3.54ubuntu1) werden verarbeitet ...But then AfterShotPro doesn't start:
Code: Select all
AfterShotPro
Install Path: /opt/AfterShotPro
LD_PATH: /opt/AfterShotPro/lib:
XLIB_SKIP_ARGB_VISUALS: 1
./AfterShotPro: error while loading shared libraries: libXrender.so.1: cannot open shared object file: No such file or directoryCode: Select all
cp /PRECISE/usr/lib/i386-linux-gnu/libXrender.so.1 /usr/lib32
cp /PRECISE/usr/lib/i386-linux-gnu/libfontconfig.so.1 /usr/lib32
cp /PRECISE/usr/lib/i386-linux-gnu/libfreetype.so.6 /usr/lib32
cp /PRECISE/usr/lib/i386-linux-gnu/libXext.so.6 /usr/lib32
cp /PRECISE/usr/lib/i386-linux-gnu/libX11.so.6 /usr/lib32
cp /PRECISE/lib/i386-linux-gnu/libexpat.so.1 /usr/lib32
cp /PRECISE/usr/lib/i386-linux-gnu/libxcb.so.1 /usr/lib32
cp /PRECISE/usr/lib/i386-linux-gnu/libXau.so.6 /usr/lib32
cp /PRECISE/usr/lib/i386-linux-gnu/libXdmcp.so.6 /usr/lib32Code: Select all
~$ AfterShotPro
Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 70: non-double matrix element
Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 78: saw unknown, expected number
0.0: I have SSE2
0.2: Bibble program arguments ("./AfterShotPro")
0.2: Loaded "/opt/AfterShotPro/supportfiles/locale/aftershot_de.qm"
0.2: Loaded "/opt/AfterShotPro/supportfiles/locale/qt_de.qm"
0.2: Loading pluginsI use Aftershot with http://xubuntu.org/
