Ok, I am looking at the info now, it says:THoff wrote:Sure UVS will edit or trim AVI videos. If you can't open them, you are likely missing a codec. Try using "Add Video", select the file, and then click on the "Info" button to view the file properties.
"Rush - 1984 Grace Under Pressure Tour"
File Format: Microsoft AVI files - OpenDML
Video Compression: Divx Decoder Filter
Audio Compression: MPEG-Layer 3
I have Dr. Divx installed and have used it several times to compress both AVI and MPEG movies, and it always saves the compressed movie as an AVI which plays just fine, so I know the Divx filter works properly.
I can place the avi on the UVS timeline and cut it wherever I want, but when i click "save trimmed video" I get the following error message:
"This AVI Codec ID cannot be trimmed."
The non-trimmed Avi plays normally through Windows Media and Divx players, so there probably isn't anything wrong with the file itself.
So far the only solution still seems to be using Nero 6 to export avi to mpeg, then trim the mpeg.
I didn't expect that I'd need to download additional codecs. If UVS says it can do X, doesn't that assume UVS comes WITH the proper codec required for performing that action? But i like UVS enough to put up with this delay.
Again, thanks in advance for your help.
