Why does burning take so long?
shenacat
Post by shenacat »
I downloaded the trial version and am making a video cd. I own the Nero package already and was distressed by the lack of options while editing VCD menus. While this package offers more options for building menus, it seems to take about 12 times as long to burn a cd as Nero.
Considering that the only difference in the data I am burning is the placement of the movie thumbnails, the font size and placement, and a slightly different background image, I do not see why the burning is taking so long. My video files are already compatible MPEG files and are not being converted, just burned. It is the title that is taking forever to "convert".
Is there something I can do to speed the process up, or is this package just really deficient in this area?
ploggy
Post by ploggy »
what the properties of your MPEGs? right click on the clip and select media properties.
shenacat
Post by shenacat »
Format: MPEG-1
Duration: 1369.161 Seconds
Video Type: MPEG-1 Video
Total Frames: 32,827 Frame(s)
Attributes: 24 bits, 352x240m 4:3
Frame Rate: 23.976 Frames/Sec
Data Rate: 1150 kbps
Audio Type: MPEG Audio Layer 2 Files
Total samples: 60,379,992 Samples
Attributes: 44100 Hz, 16 bit, Stereo
Layer: 2
Bit Rate: 224 kbps
Would this effect the title conversion so much?
AnimeChick
Post by AnimeChick »
It would at least require MF to convert it to MPEG-2. MPEG 1 is used in VCD so that would explain why it is faster. DVD uses MPEG 2.
shenacat
Post by shenacat »
I'm slightly confused by your comment, AnimeChick. I am burning a VCD with MF, not a DVD. The same VCD takes much longer to burn on MF than it does on Nero. Are you saying that MF has to re-convert my MPEG-1 files to MPEG-2?
AnimeChick
Sorry. Didn't read in detail. So many people here are making DVDs. Suggestion revoked.
