EXIF info
brucet
operating_system: Windows 8.1
EXIF info
Post by brucet »
Is there an easy and 'fool proof' way of stripping EXIF info from jpegs in PSPx6? Sometimes I get no details and yet other times details are left available.
regards
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: EXIF info
Post by LeviFiction »
Yes.
I don't know if there is a built in command inside of PSP you can just click. But there is a script command called "DeleteEXIF" that you can run. It will delete everything except for the author name and copryright info.
If you want to delete it all, all. You will need a different tool. There are a few meta-data strippers out there.
Just copy and paste this into a text file. Name it DeleteEXIF.pspscript Should work version 9 up..maybe. I only tested it in X6.
Code: Select all
from JascApp import *
def ScriptProperties():
    return {
        'Author': u'',
        'Copyright': u'',
        'Description': u'',
        'Host': u'PaintShop Pro',
        'Host Version': u'9.00'
def Do(Environment):
    # EnableOptimizedScriptUndo
    App.Do( Environment, 'EnableOptimizedScriptUndo', {
            'GeneralSettings': {
                'ExecutionMode': App.Constants.ExecutionMode.Default,
                'AutoActionMode': App.Constants.AutoActionMode.Match,
                'Version': ((9,0,0),1)
    # Delete EXIF
    App.Do( Environment, 'DeleteEXIF', {
brucet
Re: EXIF info
Post by brucet »
Thanks. But I'm getting a 'script' error?
regards
ram: 6 GB
Re: EXIF info
What is the error?
photodrawken
ram: 16Gb
Hard_Drive_Capacity: 324Gb
Re: EXIF info
Post by photodrawken »
LeviFiction wrote:If you want to delete it all, all. You will need a different tool. There are a few meta-data strippers out there.
I can recommend the ExifToolGUI, which (not surprisingly) is a graphical user interface to the ExifTool commandline application:
http://u88.n24.queensu.ca/~bogdan/
From that page you can download the ExifTool and the ExifToolGUI.
Not only does it have the "Delete All Metadata" option, but it's also an excellent tool for looking at all the metadata of an image....
Ken
brucet
Re: EXIF info
Post by brucet »
LeviFiction I picked up 'script' error when I copied and pasted to a text file. I now know where the error is/was.
Thanks.
