VideoStudio Upgrade X6 to X7 Am I Screwed?
ThatGuy
Post by ThatGuy »
What happened to 640x480 MPG4 option???
My movies are stretched (hideous), WTF???
Re: VideoStudio Upgrade X6 to X7 Am I Screwed?
Have you set the aspect ratio to 4:3 instead of 16:9?
Are you using a Custom profile for outputting the new video? Have you thought of using Share > Same As First Clip (if the first clip is 640 x 480)?
Yep I agree that the default 640 option seems to have disappeared.
Press the + symbol to set a new profile
640 x 480 is available if you use H264Main (Video Type) or lower compression.
If you set H.264 high the frame size starts at 720 x 480
MPEG-4 Files
24 bits, 640 x 480, 25 fps
Frame-based
H.264 Main Profile Video: 4000 Kbps
48000 Hz, 16 Bit, Stereo
MPEG AAC Audio: 256 Kbps
ThatGuy
Post by ThatGuy »
Ken Berry wrote:Have you set the aspect ratio to 4:3 instead of 16:9?
You probably don't realize it but you ducked my question...
Am I using the aspect ratio to 4:3 instead of 16:9? Well of course I am because there's an easy to find little button right there on that section in Share and you just click it and bingo, right? (No, not right...)
Am I using a Custom Profile? Well of course I am because I was notified in advance by Corel that to do the SAME movie-making I was already doing I'd NEED Custom Profiles and Corel provided a Wizard so I could define those Custom Profiles, right? (No, not right...)
Anyway, it works now, by changing the compression.
Thanks...
ThatGuy
Post by ThatGuy »
BINGO! I had used + to make a new profile but missed the change-compression thingy... It works now.
THANKS!
VideoStudio X8 Wish List:
1. If something was there, and it worked, leave it alone.
2. If something was there, and it didn't worked, make it work, then leave it alone.
3. If something wasn't there, and nobody asked for it, don't do it.
4. If something wasn't there, and a bunch of paying customers asked for it, do it, do it correctly and completely before releasing it, then leave it alone.
lata wrote:Hi
MPEG-4 Files
Frame-based
ThatGuy wrote:
Ken Berry wrote: Am I using a Custom Profile? Well of course I am because I was notified in advance by Corel that to do the SAME movie-making I was already doing I'd NEED Custom Profiles and Corel provided a Wizard so I could define those Custom Profiles, right? (No, not right...)
Thanks...
If I understand you correctly then Yes its right, there is a Wizard if that's what you wish to call it, doesn't do magic though.
Make Movie Templates Manager, (X7 Movie Profile Manager) is similar to using the Custom options in the way you set the properties.
Once done the template is always available adjacent to the Custom option.
