Videostudio X7 Registration Issues - Corel Guide access
Re: Videostudio X7 Registration Issues - Corel Guide access
Hi Anna
Thanks for the feedback, very happy that “alexs3” solution has worked for you.
And again thank you Alex3.
Hopefully all other users having a similar problem will now apply the fix.
brunob
processor: Intel Core i7-2720QM CPU 2.20GHz Total
ram: 8 GB
Video Card: nvidia nvs 4200m
Hard_Drive_Capacity: 500 GB
Monitor/Display Make & Model: DELL2407WFPHC, 24.2"
Post by brunob »
I am happy for you Anna,
In my case I tried but it did not work. If I delete the "Message"folder, when I click on the Orange icon Videostudio registration window does not open anymore!
In my case I have also Videostudio X6 installed and it is working perfectly, I don't know if this is influencing the way X7 behaves!
Cheers
Bruno
Gyozo
motherboard: Asus P5Q deluxe
processor: Core 2 quad 9400
ram: 8Gb
Video Card: Ati Hd9650
sound_card: Integralt
Hard_Drive_Capacity: 500Gb
Post by Gyozo »
This method is worked for me, too!
1. From the control panel windows set to default settings the Internet Explorer
2. In Internet Explorer settings add properties to trusted hosts http://www.corel.com, iws.corel.com, apps.corel.com, corel.com. For trusted sites allow all ActiveX launch options.
3. Clear the cooke and cache in Internet Explorer.
4. For Windows 7. Remove the all files in the SystemDrive:\Users\UserName\AppData\Roaming\Corel\Messages (Example c:\Users\Poll\AppData\Roaming\Corel\Messages)
Thank you!
sirhill
Post by sirhill »
Thanks it worked for me too
RobertOZ
Hard_Drive_Capacity: 7 TB
Post by RobertOZ »
brunob wrote:I am happy for you Anna,
Cheers
Bruno
You don't delete the folder, delete the contents of the folder, if you have deleted the folder, create a new one named "Messages"
Robert
Hi Bruno
Did you also adjust the Internet Explorer settings as mentioned in Alex's fix.
brunob
ram: 8 GB
Post by brunob »
This is just to inform you that finally I resolved my issue by....installing X7 clean on a new computer! What happened is that at a certain point of the investigation Corel Support suggested to me to remove a old Windows Update that could have interfered. After I did it, the computer died (the hard disk partition was lost!). Having restarted clean (really clean, just from the new Windows 7!), the installation went OK and I could sign-in. My impression is that the issue was due to the existing version of X6 on my previous computer. When I installed X7 it asked me if I wanted to import the library from X6 and I say yes. I realised later, going through the Messages folder, that X7 also imported the Bonus package where the X6 registration was included! I guess this could have created the problem when trying to register (sign-in) the X7 version.
Post by BrianCee »
Thank you for the feedback
yvonne chuang
motherboard: Intel
processor: Intel P7450
ram: 4GB
Video Card: ATI HD 4570
sound_card: Realtek
Hard_Drive_Capacity: 1TB
Post by yvonne chuang »
Dears,
If you encountered the problem with the blank registration page, then please do below steps to fix:
1. Run "Check for update"
2. Close the application and launch it again
Then, this issue should be able to be resolved.
The root cause for this issue is because the online content isn't being published correctly. We have fixed it from server and via above steps, it can fix this problem.
Thanks,
Yvonne
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Post by df »
That worked for me. Thanks Yvonne.
Regards, Dan
catplace
motherboard: Gigabyte GA-P67A-UD4-B3
processor: Core i7-2600K
Video Card: nVidia 570
sound_card: Soundblaster Fatality
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Samsung B2440
Post by catplace »
I'm suffering the same problem too, but with X8 (trial). I've tried all the suggestions in this thread, but still get the blank window after entering my email address.
I suspect that a previous installation of Ulead VideoStudio 11 is interfering—even though I uninstalled that prior to installing the X8 trial. The reason I suspect this is that, when I use Alt+backarrow in the blank window, I get to an old corel web page that mentions 11.
I've searched through the registry looking for 'videostudio', but all the references seem to apply to X8. Perhaps X8 is picking up something from a folder used by 11 (although that would seem odd).
I don't have the confidence to risk buying X8 if I won't be able to register it. :(
Any further suggestions would be most welcome!
catplace
Post by catplace »
Further to my previous, if I click 'Register' without entering an email address, the window (which would otherwise go blank) loads the following page:
(This is a composite image, pasted together using Paintshop Pro X7—which works perfectly.)
This page really looks defunct. If anyone knows where the VS X8 installer might be picking it up from, I might be able to find and remove the offending vestige from my computer.
Post by BrianCee »
Since you already have PaintShop then you have an account on the Corel website - have you tried logging in to that and choosing "Register a New Product "
catplace
Post by catplace »
Thanks for the reply, Brian! When I try that, the web site asks me for the product's serial number. Since I'm only running the trial version so far, I don't have any paperwork with the serial number, and because I can't start the program, I can't see its serial number in the help menu. It's a chicken-or-the-egg.
I'm scared to buy the program just to get a serial number in case I still can't enter it into the program due to the blank window.
I should also mention that I receive a 'thank you for registering' email from Corel whenever I go past the panel where you enter your email address. I've got 38 such emails now. Despite that, the next panel never loads and the web site doesn't indicate any registration (for the trial version or any other).
Post by BrianCee »
Can you use the programme apart from accessing the Corel guide - some people find that that does not populate until a couple of days after you use the programme
