IN C3DPS I’m making a 150 frame animation. An object rotates frames 1-60. I want it to stay still for 30 frames (T ill 90) than rotate another 60 frames.
I do the first rotate than I want it to stay still, so I go to frame 90 and push the thumbtack button for orientation and position, nothing happens to either one…
Am I doing this right?
Can you suggest a better way?
SOMEONE PLEASE HELP!!!!!!
does the thumbtack work?
OinkyPig
It is quite easy.
1st select the object.
Go to frame 60, On the timeline, choose the orientation bar, rotate the object to where you want it to be. This automatically adds a keyframe on the bar
Then go to frame 90, on the orientation bar, "Add Keyframe" but do not change any orientation.
Lastly go to frame 150, choose Orientation, and rotate the object to where it is supposed to end at.
Run the Navigation Toolbar "Play" and it should display a rotation from frame 0 to 60, pause for 30 and continue to rotate to frame 150.
Cheers
Cheers
OinkyPig
Open Timeline Tool Bar,Wolfy215 wrote:Then go to frame 90, on the orientation bar, "Add Keyframe" but do not change any orientation.
that's what i was trying to do with thumbtack. how do you add a keyframe wwithout changing anything?
There is a + icon with a little triangle on the lower left corner.
That just adds a keyframe without changing anything.
If you can't find it, probably got to mail a picture of it to you
Hope it helps
OinkyPig
I discovered it by accident too.. cause I had the same problem when I 1st started outWolfy215 wrote:thank you oinky pig,
but i feel sooo stupid
thank you too ken for replying
Some of my 1st few questions where also "stupid" questions...
Anyway, we are learning every time we dare to ask something.
Have a nice day
