VideoStudio X7 and Debugmode FrameServer
gca
- motherboard: Z68X-UD3H-B3
- processor: I7 2600K
- Video Card: GTX 550 Ti
- Monitor/Display Make & Model: HANNS-G HL249
Does anybody tried to use VS X7 with Debugmode Frameserver? I try that with all versions of VS started with X2 till X6 with succes but not with X7. Any suggestions? Thank you.
Re: VideoStudio X7 and Debugmode FrameServer
Are you using the 64bit version of X7 ? - have you tried it in the 32bit version ?
gca
Yes I have tried both versions, same problem.
gca
It seems that nobody use vs X7 with debug frameserver.
gca,
GOOD NEWS!
I just confirmed DebugMode FrameServer 2.14 worked using Corel VideoStudio Pro X6 and TMPGEnc 4.0 XPress. Using the Ulead Video Studio plugin, one needs to direct installation to the correct location.
Example: C:\Program Files\Corel\Corel VideoStudio Pro X6\vio
P.S. I had always installed the Ulead MediaStudio Pro plugin and that is why it never worked for me with Corel VideoStudio Pro. I uninstalled my prior FrameServer installation through Control Panel Add/Remove Programs and deleted DebugMode folder in Program Files and deleted the HKEY Software DebugMode entries in the Registry. I then installed the fssetup-2.14.exe and chose both Ulead MediaStudio Pro and Ulead Video Studio plugins. Learn something new everyday.
Hope this helps.
Robert
GOOD NEWS!
Hope this helps.
Robert
- krank35
- motherboard: MSI H97M-G43
- processor: Intel CORE I7
- ram: 16Go
- Video Card: NVIDIA GeForce GT 640
- Hard_Drive_Capacity: 3 T
- Monitor/Display Make & Model: IIYAMA 1920*1080
- Corel programs: VideoStudio
i confirm Debugmode FrameServer dont work with x7 !
Curious
- Corel programs: VS X8, X7, X6, X4, X3, X2
i confirm Debugmode FrameServer v2.14 dont work with videostudio x8 neither!
It will generate an audio only file (the post file), but the plugin won't start up in vs to frameseve the video frames like it was in vs x4 and x6 if i remember correctly. Too bad.
