I have been using PSP X5 on my Win 7 desktop PC, which has now died. My replacement PC runs Win 8.1 (64 bit). I have used the original disc to install PSP X5 on the new machine and on the whole it seems to work OK, but I have spotted at least one problem; the option for screen capture under File > Import is greyed out.
Is this a known problem with Win 8.1, or is there something I can do to regain the capability for screen capture?
Screen Capture Has Disappeared - Is It Windows 8.1?
Forriner
- motherboard: ASUS Z170M-PLUS
- processor: Intel Core i5-6400
- ram: 16 GB
- Hard_Drive_Capacity: 1250 GB
- Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
- Corel programs: PSP 2023
Re: Screen Capture Has Disappeared - Is It Windows 8.1?
You installed from DVD, have you installed service packs? Try here: http://corel.force.com/index/articles/e ... nd-Updates
Service packs shouldn't be needed for screen captures though. The only thing I can think of is resetting PSP to default configuration: press and hold a shift key while clicking on the shortcut to start PSP. Answer Yes when asked if you want to reset. It's worth a try anyway.
good luck.
good luck.
cookie1234
- Monitor/Display Make & Model: Dell UltraSharp 25 Monitor
- Corel programs: PaintShop Pro 2018 Ultimate
Try pressing the Windows logo + PrtSch. Windows 8.1 should automatically make a new folder "Screenshots" under "Pictures" folder. I don't think you can print directly from screen; but you can print from the saved file.
MarkZ
- motherboard: Intel DQ67SW desktop
- processor: Intel Core i7 i7-2600 3.40 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: LG Flatron E2241
- Corel programs: PSP 2018 X9 X8 X7 X6 ASP3 ASP
I do a Print Screen then in PSP Edit mode Menu/Edit/Paste as new image.
Mark
