VideoStudio X6 and RotoPen
tfrenz
motherboard: Notebook Sony VPCSA
processor: Core i7
ram: 6GB
Monitor/Display Make & Model: 23" LG 24EB23
Post by tfrenz »
I have an problem.
In my video i have insert an JPG-Map. Then i have create a route with ProDAD RotoPen (is in VS X6 Pro included).
If i make an Video in 760x520 Pixel, the map can't read.
If i make an Video in 1920x1080 Pixel, the Route is not on the original Position.
Is there an Parameter to correct the Possition?
My Computer is an Sony Vaio with 6GB RAM on Windows 7 Pro 64 Bit.
Thanks for infos.
Thomas Frenz
RobertOZ
Hard_Drive_Capacity: 7 TB
Re: VideoStudio X6 and RotoPen
Post by RobertOZ »
This question has recently been asked and answered, see if they help you
http://forum.corel.com/EN/viewtopic.php?f=1&t=53355
http://forum.corel.com/EN/viewtopic.php ... en#p286492
Robert
Hi Thomas Frenz
Welcome to the forums
The problem arises with using a different image size/shape than the video frame.
Your image should use 16:9 ratio. Assuming your video is widescreen.
Using an image editor resize/crop your map to use 16:9 ratios.
1920 x 1080 would be 16:9
If the map image has larger dimensions try to retain those as best as possible.
My camera creates Jpegs 5184 x 3456, I would crop to 5184 x 2916 (16 x 9 ratio)
Hope that helps.
pepegota
motherboard: ASUS TUF Z390-Plus
processor: Intel i9 - 9900k
ram: 64 GB
Video Card: GTX 1660 6GB
sound_card: On board sound
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Ben Q, "21" LCD
Corel programs: VS 2018, VS 2019, VS 2020
Post by pepegota »
Just go into Photoshop and create a 16:9 or 4:3 frame (white, transparent or an appropriate color.) Place your map in that frame. Make sure frame size and project settings are the same (16:9,for the created frame, or 4:3, if that's the size.) Now, it will work. Simple.
canuck
operating_system: Windows 8.1
Post by canuck »
pepegota wrote:Just go into Photoshop and create a 16:9 or 4:3 frame (white, transparent or an appropriate color.) Place your map in that frame. Make sure frame size and project settings are the same (16:9,for the created frame, or 4:3, if that's the size.) Now, it will work. Simple.
Most users do not have PhotoShop :(
pepegota
ram: 64 GB
Post by pepegota »
I would think that if you are serious about making movies you would have Photoshop (Elements) or a facsimile. Even a novice uses PS for their pics modifications. You certainly need more than VS for photo mods and good movie making.
