How to install the 32 bit version?
Hko
motherboard: ASUS M4A78T-E
processor: AMD Phenom X2 545
Video Card: Radeon HD 3300 on-board graphics solution
sound_card: EMU 0404 USB
Hard_Drive_Capacity: 1TB
Post by Hko »
I only installed the 64 bit version of X6 and thought that I can always install the 32 bit version later on if needed. It seems that the installer will want to first remove my 64 bit installation, i.e. it does not offer any way to install the 32 bit version without removing the 64 bit version. Has anyone else come across this and found a solution for this perhaps?
rgds
Harri
trueblue
Moderator
motherboard: ASUS Z97M Plus
processor: Intel Core i7-4790 CPU 3.60 GHz
ram: 12GB
Video Card: NVIDIA GeForce GTX 750
sound_card: NVIDIA High Def Audio Realtek High Def
Hard_Drive_Capacity: 1.740GB
Monitor/Display Make & Model: Benq E2420HD 24" wide x 2 monitors
Corel programs: PSPX8-VideoStudio-AfterShot
Re: How to install the 32 bit version?
Post by trueblue »
When installing PSPX6 it is recommended you install 32 and 64bit versions at the same time. Both use the same database. You can only use 32bit plugins in the 32bit version. Hence, using both versions.
Uninstall PSP and reinstall and select installing both as recommended.
~~~~Maureen~~~~
Creative-Designs
Free! PaintShop Pro Tutorials
Hko
Post by Hko »
Ok, guess I will have to do that.
