Help with motion tracking question
maximus01can
processor: Intel Core i7-2670QM CPU 2.20GHz
ram: 16 Gb
Video Card: NVIDIA GeForce GTX 570M 4095 MB Total available gr
Hard_Drive_Capacity: 1Tb
Post by maximus01can »
Howdy,
Question is, can an effect be hooked to a motion track or track point so that effect will track the object? I've seen in tutorials where a text box or such can be attached to the track, but being able to have an effect track would be kewl. New to running Ultimate X7.
Cheers and thanks,
Max
VS Pro X7, Sony SLT A65 DSLR Camera, Samsung Note 3, Ipad4
RobertOZ
Hard_Drive_Capacity: 7 TB
Re: Help with motion tracking question
Post by RobertOZ »
Motion Tracking ability has been part of Video Studio since X6, Gripps 2211 channel on YouTube has many tutorials which can guide you through the basics and more
https://www.youtube.com/watch?v=PuVKHjb ... yHCKJrlvzK
Robert
maximus01can
ram: 16 Gb
I have not found any that address applying an FX to a motion tracking path. Not sure if it's possible to say for example place a "Punch" or any other fx to a motion path.
Cheers,
Max
canuck
operating_system: Windows 8.1
Post by canuck »
maximus01can wrote:I have not found any that address applying an FX to a motion tracking path. Not sure if it's possible to say for example place a "Punch" or any other fx to a motion path.
Cheers,
Max
Did you watch the 1st tutorial in the link posted? It shows exactly what you want to do - attach a text effect to a motion track.
If that is not what you want then please supply more details
maximus01can
ram: 16 Gb
Applying a text effect doesn't seem to be the same as trying to apply fx effect. I tried doing it with a practice affect and couldn't seem to make it work it's probably something that i'm doing wrong.
Cheers
Max
Post by BrianCee »
What exactly do you mean by an 'fx' - do you mean a highlight or similar - or are you trying to apply something from the FX library to the moving object. You can attach anything in exactly the same way as you attach the text box - any object.
for instance you could attach a circle like this :- https://www.youtube.com/watch?v=jBTnYlPf5AM
maximus01can
ram: 16 Gb
Thanks for the help, I may just be doing something wrong then as I tried to attach a "Punch" FX to the motion track path I did of someones face to make it go all funny like the Punch effect does. But it didn't seem to work. If you can attach any type of effect to that path then it should work, I just didn't have any luck.
Cheers,
Max
Post by BrianCee »
Nobody has said you can attach an effect as a motion tracker - - only objects you may need to make a separate image of the 'punched' face and use that as the object to cover the basic face.
maximus01can
ram: 16 Gb
Yes so that answers my question you cannot apply an effect to the object motion track path and have it perform that effect to the object being tracked. Attaching a stationary image to the motion track path is basically useless when what i was trying to do was have the effect applied on the object that's being motion tracked And change as the path progressed.
Thanks for the help
Cheers
Max
aljimenez
ram: 24GB
Video Card: AMD Radeon R9 270
sound_card: AMD High Definition Audio
Post by aljimenez »
I have not done this, but could you insert the video in an overlay track. Then add the motion track and the F/X you want. You could for example crop the video to the portion you want to affect... Al
User for more than 10 years.
maximus01can
ram: 16 Gb
I believe i tried doing that and couldn't seem to make it work but once again i was probably doing something wrong . It would be nice to be able to have the fx applied to a portion of video that you want to be moving. I'm sure there's someone here a lot better at this than i am that could probably make it work though.
Cheers
Max
