I finally have my finished slide show!
It's about 38 minutes long.
Now I need to burn 10 copies.
What is the quickest & easiest way to do that?
Thanks,
Gretchen
How do I burn multiple DVD copies (10) fast?
AnimeChick
You can copy the disc itself if you have a disc burning utility like DVD Moviefactory.
Also in Pictureshow, select the option to save a disc image file. You can then load the disc image file into Uleads disc image recorder included with the program and burn from that. It will cut out the rendering process.
2log
re: How do I burn multiple DVD copies (10) fast?
If you're planning to burn multiple copies of a dvd project, next time before rendering it, create a disc image file with the burned dvd. At the burning step of PictureShow, you normally choose "Record to Disc" which is selected on default. Enable "Create Disc Image File" so that it will create a softcopy version of the dvd.
With a disc image file, next time you burn the project, it will no longer need rendering and just copy it from the disc image like a "copy disc" function would.
The disc image file is usually saved on the working folder which is the PictureShow folder on "My Documents" at default. If you don't have enough disc space on drive c, you can change the working folder.
Once you've created a disc image, you'll need to open "Ulead Disc Image Recorder" from "Start > All Programs > Ulead CD & DVD PictureShow 3 > Ulead Disc Image Recorder". Browse for the disc image which is in *.ISO format then burn as many copies as you like...
Gretchen Tapp
