Use OpenCL disabled?
Hi Folks,
I just wanted to give the OpenCL accelleration a try. But I can't enable it. The check box just does not accept the click.
I am using Linux and a Nvidia Graphics Card.
Is there anything particular I have to do to get switch it on?
Karsten
Karsten
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Re: Use OpenCL disabled?
Looks like you do not have the needed drivers installed.
Are you using the drivers directly from Nvidia?
cheers
afx
cheers
afx
Yes, I think I do.
Code: Select all
imhotep:~ # lspci -nnk | grep VGA -A2
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation NV44 [GeForce 7100 GS] [10de:016a] (rev a1)
Subsystem: Micro-Star International Co., Ltd. Device [1462:0340]
Kernel driver in use: nvidia-
afx
- System_Drive: N/A
Looks similar enough;-)
Do you have this:
/usr/lib32/libnvidia-compiler.so.331.38
(I found this lib comparing the lsof output of AS with and without OpenCL enabled)
Does the AS preferences screen show that you have an Nvidia card?
This is what I see in the AS log file:
cheers
afx
Code: Select all
$ lspci -nnk | grep VGA -A2
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GF119M [Quadro NVS 4200M] [10de:1057] (rev a1)
Subsystem: Lenovo Device [17aa:21cf]
Kernel driver in use: nvidia/usr/lib32/libnvidia-compiler.so.331.38
Code: Select all
0.130: **** Making CLManager
0.134: Got 1 platforms
0.134: OpenCL is enabled in low mem mode
0.134: platform 0xa4b9fc0 "NVIDIA Corporation" OpenCL Version: "OpenCL 1.1 CUDA 6.0.1"
0.134: device: 0xa3df360 "NVS 4200M"
0.172: ****** Device "NVS 4200M" enabled
0.172: LDS size 49152
0.172: Compute units: 1
0.172: Freqency: 1620
0.172: Max work items: 1024
0.172: Max work item sizes: 1024 1024 64
0.172: Device OpenCL Version: OpenCL 1.1 CUDA
0.172: Device OpenCL C Version: OpenCL C 1.1
0.172: Device Memory: true
0.172: Zero Copy: false
0.172: **************
0.173: Max work items: 1024
0.173: Max work item sizes: 1024 1024 64
0.173: Device OpenCL Version: OpenCL 1.1 CUDA
0.173: Device OpenCL C Version: OpenCL C 1.1
0.173: Device Memory: true
0.173: Zero Copy: false
0.173: **************
afx
Well, it's a 64 Bit System. So there is a whole bunch of nvidia 64bit libraries:
But the OpenCL function seem to be disabled
Any idea how to fix it?
Best regards,
Karsten
Code: Select all
imhotep:~ # ls /usr/lib64/libnv*
/usr/lib64/libnvcore.so /usr/lib64/libnvidia-cfg.so.1 /usr/lib64/libnvidia-ml.so /usr/lib64/libnvidia-opencl.so.304.119 /usr/lib64/libnvimage.so
/usr/lib64/libnvcuvid.so /usr/lib64/libnvidia-cfg.so.304.119 /usr/lib64/libnvidia-ml.so.1 /usr/lib64/libnvidia-tls.so.304.119 /usr/lib64/libnvmath.so
/usr/lib64/libnvcuvid.so.1 /usr/lib64/libnvidia-compiler.so.304.119 /usr/lib64/libnvidia-ml.so.304.119 /usr/lib64/libnvidia-wfb.so.1 /usr/lib64/libnvtt.so
/usr/lib64/libnvcuvid.so.304.119 /usr/lib64/libnvidia-glcore.so.304.119 /usr/lib64/libnvidia-opencl.so.1 /usr/lib64/libnvidia-wfb.so.304.119
Code: Select all
0.586: Build Mode: Release
0.586: Product Name: "AfterShot Pro"
0.587: AfterShot Pro key used. 6
0.587: Registered Version
0.587: Initializing
0.588: Cpu Manager init: 8
0.588: **** Making CLManager
0.590: Got 0 platforms
0.590: OpenCL is disabled in low mem mode
0.590: "Could not select an OpenCL platform"
0.591: **** CLManager not initialized
Best regards,
Karsten
afx
- System_Drive: N/A
Who cares about the 64bit stuff?
AS is a 32bit app.
See the library I mentioned in my post.
cheers
afx
AS is a 32bit app.
cheers
afx
There is no /usr/lib32/ at all on my system.
I'll try to install the library. Let's see whether it conflicts with something else...
Karsten
Karsten
afx
- System_Drive: N/A
Hmm,
older Nvidia drivers hat a problem and did not contain the 32bit libs, but current drivers should have them.
cheers
afx
cheers
afx
SteveCase
- System_Drive: N/A
- motherboard: ASRock 990FX Extreme4
- processor: AMD FX-8350
- ram: 16.0 GB
- Video Card: GTX 550ti
Just a thought.... Looks like you use a GeForce 7100 GS. Could be this GPU is no longer supported?
From the nvidia site.
"Thus OpenGL 3.0/3.1/3.2/3.3 is not supported on NV3x, NV4x nor G7x hardware. "
Steve in Seattle,WA
afx
- System_Drive: N/A
Steve, your quote refers to a newer version of OpenGL, not OpenCL.
cheers
afx
cheers
afx
Having solved some other issues I am back to this one.
However, there is no library "libnvidia-compiler.so.331.38" available in any of my repositories for the OpenSuSE 13.1 64bit.
Karsten
Karsten
afx
- System_Drive: N/A
You have to get it from Nvidia, not SuSE.
I just installed a brand new 14.04 Ubuntu and then Nvidia driver 331.67 on top of it and OpenCL is available.
cheers
afx
cheers
afx
