VS X7 64 bit
I cannot render to Constant Data Rate / Mpeg2 DVD
I created a template using constant data rate, after rendering my project Variable has been used.
Same results if I set the project properties to use a constant data rate, rendering same as project properties produces variable.
These are the details of my template:-
MPEG files
24 bits, 720 x 576, 25 fps
Upper Field First
(DVD-PAL), 16:9
Video data rate: 8000 kbps “constant”
Audio data rate: 256 kbps
It may well be my pc problem but is anybody able to create a template using the above details and successfully render to a Constant Data Rate VS X7 64 Bit
VS X7 Constant Data Rate for Mpeg2 DVD
Re: VS X7 Constant Data Rate for Mpeg2 DVD
I just threw a quick project together. Made a new movie template with exactly the same Properties as yours. This of course created a new Personal Profile. I then went to Share > MPEG2 and chose that new Profile. And it rendered perfectly, including with the CBR... Just to be sure, I did it again with another quick project, and again it rendered fine with the CBR.
Hi Ken
Thanks for testing, guess its my PC, its not the first time our pc’s do different things.
I have reverted to using X6 to get the constant data rate. When that’s complete I will try the constant options again???
Maybe a re-install is on the cards.
Ohh……and still no post reply notifications.
Hi Ken
Update, I have re-installed X7 64 bit, initial tests showed the Constant re Variable issue behaving itself. But not for long.
Working with standard definition mpeg2, I tried setting the project properties to match, Show Messages….. worked sometimes but not all the time, a little strange as the files are compliant.
I then tried to manually set Project Properties (alt+enter) allowed me to Reset, this option clears the User Defined templates, although the process failed, That’s when I got that dreaded error Improper Argument again.
Earlier I had set Movie Profile Manager creating two user defined templates, one for AVCHD and the other for DVD nothing unusual about them.
I have reset the program and everything seems normal with the exception of the Variable issue, now always there?
Would you mind having a mess about with Mpeg2 DVD templates, simply create a couple of profiles and maybe change the project properties. I don’t have any particular order in which I do things to cause the problem.
As I say it now seems ok, till I try again tomorrow??????
What happened today seems to link the Argument error with the Constant/Variable issue?
Sorry, Trevor, I did as you asked, and still can't replicate any problem. I set up new Profiles, with different settings -- changing bitrate, UFF, LFF and Frame Based; changing audio between Dolby and LPCM -- the only thing constant being the setting for CBR. And the rendered files all reflect the Properties in the profiles, including the CBR.
