Can't capture or preview video
aus stretch
Post by aus stretch »
I can not capture or preview video using my Canon MV 800i video camera.
Using Ulead video studio 5 dv (or any other capture program, I tried 3 others) They all will control my camera fast forward, rewind, play ect but none will display or capture any video.
My computer is an IBM CLONE, 2.8 gig, 512mg ram, onboard video and sound on a K7 motherboard, with a 3 port PCI FireWire card installed.
Operating system is Windows XP Pro.
Any ideas would be greatfully received
:lol:
THoff
Post by THoff »
Try WinDV, it is about as basic as it gets, and has minimal system requirements. The only thing it requires are a working DirectShow subsystem in DirectX (for both the capture and preview).
If that doesn't work, I would try reinstalling DirectX 9.0c and your display drivers.
aus stretch
Thanx 4 the reply.
Tried Windv... :( Same result. Cant preview and the saved file 0 frames and obviously cant be viewed.
Re installed video drivers and upgraded Directx to 9.0c.
Tried again..... :evil: Same result.
Removed and reinstalled firewire card. No Change.
My computer is recognising my camera and can control everything on the camera itself but no video.
Am pulling my hair out.
THoff wrote:Try WinDV, it is about as basic as it gets, and has minimal system requirements. The only thing it requires are a working DirectShow subsystem in DirectX (for both the capture and preview).
THoff
Post by THoff »
Open up Control Panel -> Network Connections and see if a 1394 network connection or bridge is listed. If it is and you don't use Firewire for networking, uninstall it.
I also just read about a DV capture problem when a program called "Morgan Stream Switcher" (a Windows Media Player addon) is installed. If you have that on your system, try removing it.
aus stretch
have done all of this and still no joy.
I put the firewire card back into my old system and it works fine.
Slow, but fine.
Just can't put my finger on whats going on.
Tried unistalling my video drivers and booting with a basic vga driver, no good.
I'm not a tech and have no further ideas HELP!!!!
THoff
Post by THoff »
Try downloading Sherlock 2.0 and see if any of your codecs are broken, especially if you ever installed one of those idiotic codec packs -- they tend to cause lots of problems.
aus stretch
still no luck
Have tried every thing I know (which isn't much) :oops: with no luck.
I've run sherlock and found no broken codecs.
Have included thelist at the bottom of this message.
means nothing to me but maybe you can see something
BTW Thanks for your help with this.
Codec Reporting Utility Output Text
Date and Time: 31-Jul-2005 22:41:56
System Information
Operating System = Microsoft (R) Windows XP Professional (5.01.2600)
CPU Descriptor = AMD Sempron(tm) 2800+
CPU Clock Speed = 2000 Mhz.
Total Memory = 447 Mb.
DirectX Version = 9.0c
WMI Version = 2600.0000
ACM Version = 5.00.0
Video Codecs
AVI Decompressor
FileVersion = 6.05.01.0902
CompanyName = Microsoft Corporation
FileDescription = DirectShow Runtime.
InternalName = Quartz.dll
LegalCopyright = Copyright (C) 1992-2001 Microsoft Corp.
OriginalFileName = Quartz.dll
ProductName =
ProductVersion = 6.05.01.0902
AVI Draw
ProductName =
Cinepak Codec by Radius
FileVersion = 1.10.0.6
CompanyName = Radius Inc.
FileDescription = Cinepak® Codec
InternalName = iccvid
LegalCopyright = Copyright © 1992-1995 Radius Inc., All Rights Reserved
OriginalFileName = iccvid.drv
ProductName = Cinepak for Windows 32
ProductVersion = 1.10.0.0
DivX Decoder Filter
FileVersion = 5.1.1.1031
CompanyName = DivXNetworks, Inc.
FileDescription = DivX® Decoder Filter
InternalName = DivXdec.ax
LegalCopyright = Copyright © DivXNetworks, 2001-2003
OriginalFileName = DivXdec.ax
ProductName = DivX® Decoder Filter
ProductVersion = 5.1.1.1031
DivX Decoder Filter
DivX® 5.1.1 Codec
FileDescription = DivX® Codec for Windows
InternalName = DivX4Windows
LegalCopyright = Copyright (C) DivXNetworks 2001-2003
OriginalFileName = DivX.dll
ProductName = DivX® Codec for Windows
DV Splitter
FileVersion = 6.05.01.0904
InternalName = Qdv.dll
OriginalFileName = Qdv.dll
ProductName =
ProductVersion = 6.05.01.0904
DV Video Decoder
ProductName =
DV Video Encoder
ProductName =
Indeo® video 4.4 Decompression Filter
FileVersion = 4.51.16.03
CompanyName = Intel Corporation
FileDescription = Intel Indeo® Video 4.5
InternalName = ir41_32.ax
LegalCopyright = Copyright© Intel Corporation 1994-1998
OriginalFileName = ir41_32.ax
ProductName = Intel Indeo® Video 4.5
ProductVersion = 4.51.16.03
Indeo® video 5.10
FileVersion = R.5.10.15.2.55
FileDescription = Intel Indeo® video 5.10
InternalName = ir50_32.dll
LegalCopyright = Copyright © 1994-1998 Intel Corp.
OriginalFileName = ir50_32.dll
ProductName = Intel Indeo® video 5.10
ProductVersion = R.5.10.15.2.55
Indeo® video 5.10 Compression Filter
Indeo® video 5.10 Decompression Filter
Intel 4:2:0 Video V2.50
FileVersion = 4.4.3400
FileDescription = Microsoft H.263 ICM Driver
InternalName = msh263
LegalCopyright = Copyright © Intel Corp. and Microsoft Corporation 1995-1999
OriginalFileName = msh263.drv
ProductName = Windows® NetMeeting®
ProductVersion = 3.01
Intel Indeo(R) Video R3.2
FileVersion = 3.24.0015.0003
CompanyName = Intel(R) Corporation
FileDescription =
InternalName = ir32_32.dll
LegalCopyright = Copyright Intel Corporation 1992-1995
OriginalFileName =
ProductName =
ProductVersion = Version 3.24.15.03
Intel IYUV codec
FileVersion = 5.1.2600.0 (XPClient.010817-1148)
FileDescription = Intel Indeo(R) Video YUV Codec
InternalName = iyuv_32.dll
LegalCopyright = Copyright Intel Corporation 1992-1997
OriginalFileName = iyuv_32.dll
ProductName = Microsoft® Windows® Operating System
ProductVersion = 5.1.2600.0
Microsoft DV Camera and VCR
FileVersion = 5.3.0000000.900 built by: DIRECTX
FileDescription = WDM Streaming ActiveMovie Proxy
InternalName = ksproxy.ax
LegalCopyright = © Microsoft Corporation. All rights reserved.
OriginalFileName = ksproxy.ax
ProductVersion = 5.3.0000000.900
Microsoft H.261 Video Codec
FileDescription = Microsoft H.261 ICM Driver
InternalName = msh261
OriginalFileName = msh261.drv
Microsoft H.263 Video Codec
Microsoft MPEG-4 Video Decompressor
FileVersion = 8.00.00.4477
FileDescription = Microsoft MPEG-4 Video Decompressor
InternalName = mpg4ds32.ax
LegalCopyright = Copyright (C) Microsoft Corp. 1996 - 2001
OriginalFileName = mpg4ds32.ax
ProductName = Microsoft MPEG-4 Video Decompressor
ProductVersion = 8.00.00.4477
Microsoft RLE
FileVersion = 5.1.2600.0 (xpclient.010817-1148)
FileDescription = Microsoft RLE Compressor
InternalName = msrle32.dll
OriginalFileName = msrle32.dll
Microsoft Screen Video Decompressor
FileDescription = Microsoft Screen Video Decompressor
InternalName = mss1.ax
LegalCopyright = Copyright (C) Microsoft Corp. 1999 - 2001
OriginalFileName = mss1.ax
ProductName = Microsoft Screen Video Decompressor
Microsoft Video 1
FileDescription = Microsoft Video 1 Compressor
InternalName = msvidc32.dll
OriginalFileName = msvidc32.dll
MJPEG Compressor
ProductName =
MJPEG Decompressor
ProductName =
MPEG Video Decoder
ProductName =
Mpeg4 Decoder DMO
FileDescription = Windows Media MPEG-4 Video Decoder DMO
InternalName = mpg4dmod.dll
LegalCopyright = Copyright (C) Microsoft Corp. 1992-2001
OriginalFileName = mpg4dmod.dll
ProductName = Microsoft® Windows Media Services
QT Decompressor
ProductName =
VBI Surface Allocator
FileDescription = VBI Surface Allocator Filter
InternalName = VBISURF.AX
OriginalFileName = VBISURF.AX
Video Port Manager
ProductName =
Windows Media Video Decoder
FileDescription = Windows Media Video Decoder
InternalName = wmvds32.ax
LegalCopyright = Copyright (C) Microsoft Corp. 1996-2001
OriginalFileName = wmvds32.ax
ProductName = Windows Media Video Decoder
FileVersion = 8.0.0.4000
FileDescription = Windows Media Video Decoder V8
InternalName = wmv8ds32.ax
OriginalFileName = wmv8ds32.ax
ProductName = Windows Media Video Decoder V8
ProductVersion = 8.0.0.4000
Audio Codecs
ACELP.net
FileVersion = 3.02
CompanyName = Sipro Lab Telecom Inc.
FileDescription = Audio codec for MS ACM
InternalName = sl_anet.acm
LegalCopyright = Copyright © Sipro Lab Telecom Inc. 1998-99
OriginalFileName = sl_anet.acm
ProductName = ACELP.net Audio Codec
ProductVersion = 3.02
ACELP.net Sipro Lab Audio Decoder
FileVersion = 1.40
FileDescription = ACELP.net Audio Decoder
InternalName = AcelpDec.ax
LegalCopyright = Copyright (C) 1997-99 Sipro Lab Telecom Inc.
OriginalFileName = AcelpDec.ax
ProductName = ACELP.net Audio Decoder
ProductVersion = 1.40
ACM Wrapper
ProductName =
C-Media Wave Device
FileVersion = 6.05.01.0900
InternalName = QCap.dll
OriginalFileName = QCap.dll
ProductName =
ProductVersion = 6.05.01.0900
CCITT A-Law
FileDescription = Microsoft CCITT G.711 (A-Law and u-Law) CODEC for MSACM
InternalName = Microsoft CCITT G.711 (A-Law and u-Law) CODEC for MSACM
OriginalFileName = msg711.acm
CCITT u-Law
DSP Group TrueSpeech(TM)
FileVersion = 1.01
CompanyName = DSP GROUP, INC.
FileDescription = DSP Group TrueSpeech(TM) Audio Codec for MSACM V3.50
InternalName = tssoft32.acm
LegalCopyright = Copyright DSP Group, Inc. 1993-1996
OriginalFileName = tssoft32.acm
ProductName = DSP GROUP Windows NT(TM) TrueSpeech CODEC
ProductVersion = 1.01
GSM 6.10
FileDescription = Microsoft GSM 6.10 Audio CODEC for MSACM
InternalName = Microsoft GSM 6.10 Audio CODEC for MSACM
OriginalFileName = msgsm32.acm
IAC2
FileVersion = 2.05.53
FileDescription = Indeo® audio software
InternalName = iac25_32.ax
LegalCopyright = Copyright © Intel Corp. 1997
OriginalFileName = iac25_32.ax
ProductName = Indeo® audio software
ProductVersion = 2.05.53
IMA ADPCM
FileDescription = IMA ADPCM CODEC for MSACM
InternalName = IMA ADPCM CODEC for MSACM
OriginalFileName = imaadp32.acm
Microsoft ADPCM
FileDescription = Microsoft ADPCM CODEC for MSACM
InternalName = Microsoft ADPCM CODEC for MSACM
OriginalFileName = msadp32.acm
Microsoft G.723.1
FileDescription = Microsoft G.723.1 CODEC for MSACM
InternalName = msg723
OriginalFileName = msg723.acm
Modem #5 Line Record
ProductName =
MPEG Audio Decoder
ProductName =
MPEG Layer-3
FileVersion = 1, 9, 0, 0305
CompanyName = Fraunhofer Institut Integrierte Schaltungen IIS
FileDescription = MPEG Layer-3 Audio Codec for MSACM
InternalName = l3codec.acm
LegalCopyright = Copyright © 1996-1999 Fraunhofer Institut Integrierte Schaltungen IIS
OriginalFileName = l3codec.acm
ProductName = MPEG Layer-3 Audio Codec for MSACM
ProductVersion = 1, 0, 0, 0
MPEG Layer-3 Decoder
FileVersion = 1, 5, 0, 50
FileDescription = MPEG Layer-3 Audio Decoder
InternalName = L3CODECX.AX
LegalCopyright = Copyright (C) 1997 Fraunhofer IIS
OriginalFileName = L3CODECX.AX
ProductName = MPEG Layer-3 Audio Codec for Microsoft DirectShow
ProductVersion = 1, 5, 0, 50
PCM
Windows Media Audio Decoder
FileDescription = Windows Media Audio Decoder
InternalName = msadds32.ax
LegalCopyright = Copyright (C) Microsoft Corp. 1999-2001
OriginalFileName = msadds32.ax
ProductName = Windows Media Audio Decoder
Windows Media Audio V1
InternalName = msaud32
OriginalFileName = msaud32
Windows Media Audio V2
Broken Codecs
[No codecs were found broken.]
