hello,
I tried to change the white balance but with tif or with a jpeg I'm unable to change the settings (manually) I'm only able to use the color picker like tool,
anybody knows how to do this?
Regards
Stefanve
unable to manual change white balance
jknights
- motherboard: Apple
- processor: Intel 3.08GHz Dual processor Quad Core
- ram: 24GB
- Video Card: ATI Radeon X1600
- sound_card: Intel HDA
- Hard_Drive_Capacity: 6TB
- Monitor/Display Make & Model: Apple Display
Re: unable to manual change white balance
The feature you want is not supported/provided.
Still learning after all these years!
stefanve
- processor: Intel Core i7 - 3610QM
- Video Card: Nvidia GT630M
- Hard_Drive_Capacity: 500GB
Thank you,
So I will have to wait for ASP 2 or start using Windows ;s.
Although I found other ways to accomplish a bit of the same effect...
brucet
Changing white balance is a Raw feature. No program, to my knowledge, will/can truly change white balance once it has been converted from Raw.
regards
regards
afx
- System_Drive: N/A
- Video Card: FirePro 4900
Yup,brucet wrote:Changing white balance is a Raw feature. No program, to my knowledge, will/can truly change white balance once it has been converted from Raw.
But a color balance for cooked images would not be hard to implement...
I personally would not want this hidden in the WB but in a dedicated tool (see the implementation in PWP).
cheers
afx
stefanve
I think you will be okay with 16-bit tif though , should contain more than enough information to allow for small adjustments. (in any case it works like a charm with lightroom )brucet wrote:Changing white balance is a Raw feature. No program, to my knowledge, will/can truly change white balance once it has been converted from Raw.
regards
But I got a bit of the same effect with the color correction tool .
brucet
There are a multitude of ways to change colours. But that's a different subject to changing White Balance. We need to be careful not to mix them up.
Us old buggers can mix n match and know, or think we know, what we are doing. But we need to be careful not to confuse those still coming to grips with editing.
regards
regards
