How do you convert a merged object
- jparnold
- motherboard: Gigabyte Z390 UD
- processor: Intel Pentium i7 9700 3dot6Ghz
- ram: 16GB DDR3
- Video Card: Gigabyte RTX2060 OC 6GB
- sound_card: Onboard Realtec ALC887
- Hard_Drive_Capacity: 2048Gb mix
- Monitor/Display Make & Model: Samsung S27C450B
- Corel programs: Videostudio X10, Paint Shop Pro 2018
I have noticed for some time that certain 'actions' done to an image then prevent you performing other 'actions' (for example pasting an image into another). In the past I have resorted to saving the image and then reopening it so that I can continue and when I save the image I get the following message -
Because of the limitations of the specified file format ........ the saved file will be limited to a merged object.
There must be a method (something to select and/or click on) so that the image becomes 'merged' so that I can continue editing the image.
Please advise
John
Please advise
John
John a
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: How do you convert a merged object
I have no idea what you're talking about.
Pasting an image into another image shouldn't stop you from doing anything.
If you want to merge or flatten all layers you can do so from the Layers palette, or from the Layers menu.
- hartpaul
- ram: 8 Gb
Hi John, You are not using text are you? If the text has not been applied it can seem that the rest of the computer is locked up.
Have sent you a PM.
Have sent you a PM.
Forriner
- motherboard: ASUS Z170M-PLUS
- processor: Intel Core i5-6400
- ram: 16 GB
- Hard_Drive_Capacity: 1250 GB
- Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
- Corel programs: PSP 2023
Saved will be limited to a merged object
If you're trying to save a file that has layers (even just one layer, Raster 1 instead of Background) as anything but a .pspimage which support layers, PSP warns you that it will flatten -merge all- the file before saving.
Many things you do while editing create layers, some temporary, some permanent. For example, if you open a JPG and just click on it with the move tool the Background is promoted to a layer (raster 1) and you'll get the warning if you try to save it as a JPG.
So consider it a warning: if you want to lose the layers, let PSP merge while saving. Otherwise, cancel and save as .pspimage.
If you don't want a warning, menu Layers/Merge/Merge all before saving.
Kathy_9
- Hard_Drive_Capacity: 2TB
If you save your image as a psimage file instead of a jpg the layers will not be flattened and you can edit away on each of the individual layers the next time you open it.jparnold wrote: Because of the limitations of the specified file format ........ the saved file will be limited to a merged object.
John
- jparnold
- ram: 16GB DDR3
Thanks for your replies.
What I am doing is
1) open a .jpg image file.
2) Open a NEW 'image' (File>New) with a pixel size larger than the image file opened at step 1
3) Select window with image in step 1 and COPY
4) select NEW image (refer step 2)
5) PASTE AS A NEW SELECTION (Ctrl E)
6) Now I cannot do anything with that area of the NEW 'image' not covered with the image pasted (eg if I paste into the center leaving the default color used to create the NEW image I cannot FILL, PAINT or anything else into the area not covered with the pasted image).
Please note that this is also while the edge of the image pasted has the 'dotted 'line around the pasted image (like you get when you select part of an image).
I thought there might be an easier way of continuing editing without having to save (merged) and then having to re-open.
What I am doing is
John a
- ram: 6 GB
From the selections menu go
Selections -> Deselect
Zacabeb
- motherboard: ASUS B450-F
- processor: AMD Ryzen 5 3600
- ram: 16 GiB
- Video Card: nVidia GeForce RTX 2060
- sound_card: RealTek Integrated Audio
- Hard_Drive_Capacity: 3 TB
- Monitor/Display Make & Model: Philips 236V4
- Corel programs: PaintShop Pro X6, PaintShop Pro 2021
While the selection is active after pasting an image, it protects the area around it from changes like a regular selection would.
You either need to manually deactivate the selection around the pasted image (Ctrl+D) after positioning it, or instead paste it as a new layer (Ctrl+V), which will center it in the canvas but allow moving it around with the Move tool.
- jparnold
- ram: 16GB DDR3
Thanks Zacabeb
Perfect. I knew there must be an easy way.
John a
- hartpaul
- ram: 8 Gb
For what you seem to be doing, Paste as New Layer would probably suit better and then you can move it around, paint on it , erase parts of it etc and lastly Layers Merge > Mergeall /flatten to finish before then saving.
Any particular reason why you needed to "Paste as New Selection"?
Joelle
- motherboard: Asus Prime B350M-A
- processor: AMD Ryzen 5 1500 Quad-Core
- ram: 16 GB RAM
- Video Card: NVidia GeForce GTX 1050
- Hard_Drive_Capacity: 1TB
- Corel programs: PaintShop Pro X9
Have you looked under File>Preferences>General Program Preferences>Warnings and also Auto Action to see what's ticked/not ticked that's generating the message.jparnold wrote:I have noticed for some time that certain 'actions' done to an image then prevent you performing other 'actions' (for example pasting an image into another). In the past I have resorted to saving the image and then reopening it so that I can continue and when I save the image I get the following message -
Please advise
John
Joëlle
Joëlle
(PSPX9 )
(PSPX9 )
