The easiest way may be from your camera menu.
Otherwise connect sd card to pc via a card reader, use windows explorer to format card.
Formatting the card will delete all data on card.
Need to format SD card before use
Terfyn
- motherboard: ASUSTeK P8H61-MX
- processor: Intel Corei5-2320
- ram: 8Gb
- sound_card: NVIDIA High Def Audio
- Monitor/Display Make & Model: Acer & LG
- Corel programs: VS X10 and PSP X8
Re: Need to format SD card before use
No!! Formatting the card in a PC will not set up the required folders on the card. It is critical to format the card in the camera to set up certain folders used, not only for recording video and stills, but for housekeeping.lata wrote:Hi
If you format in your PC you will just wipe the card.
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
If you are talking about the card in your camcorder you need to insert it and find "format card" or similar in the cams menu and follow the instructions there
Hi Terfyn
When I format my SD card on the pc all data is removed, the card is like new.
When I place that SD card in my camera, turn the camera on, before taking any recordings, the camera creates files on that card.
DCIM
MISC
PRIVATE
Those folders being used to save the video / images.
It is not essential to format on camera, although that is my preferred method.
DCIM
MISC
PRIVATE
Terfyn
- ram: 8Gb
Maybe they have changed the software because when I carried out the same process the card failed and I had to re-format it in the camera. That is why I always recommend that the card is formatted inside the camera and not in a PC.lata wrote:Hi Terfyn
DCIM
MISC
PRIVATE
