Perfectly Clear...batch process AND/OR saving prefs?
joe1512
Post by joe1512 »
I played with Perfectly Clear some and I can see that it could be useful as an automated pre-fixer type filter. The problem is that it is a PLUGIN and thus you run it with 1 picture at a time...that you are already in Edit mode with in PSPX6.
Furthermore, every time I run PC, it starts with default preset.
I would like to automate this to run a series of files. I would appreciate any help on how to do so better.
I created a Script that basically just runs Perf Clear then Saves the file. When executed however it always stops at the Plugin...Perfectly Clear in this case of course... and with the default preset set (whereas Id like to use Noise reduction as standard). I'd also like to programatically click the OK button in PC so it will do more than 1 without me having to click Noise Reduction then OK.
I could even do a screen-recording macro (the playback kind) with another piece of software, but the variable processing times makes this fairly fragile and not very friendly to use.
I'd appreciate your ideas.
