TGA puzzle
terrypin
motherboard: Asus Z170 Pro 4
processor: Intel Core i7 6700K 4.0GHz
ram: 32 GB
Video Card: None - uses built-in graphics
sound_card: HD onboard sound card
Hard_Drive_Capacity: 4.256 TB
Monitor/Display Make & Model: iLyama Prolite E2403WS 24" 1920x1200
Corel programs: Paint Shop Pro 8; Paint Shop Pro 2018
TGA puzzle
Post by terrypin »
I've rarely used TGA files but I'm playing with a folder of them now and would appreciate some insight into how PSP 8 handles these files please. This is the one that has me particularly baffled:
https://dl.dropboxusercontent.com/u/401 ... icOval.tga
IrfanView displays it correctly, with the grey representing transparency. But PSP 8 shows no transparency at all. If I examine the interior, every pixel appears to be pure white (255,255,255). And the Layer palette just shows a Background.
Does PSP 8 not support TGA files?
Terry, East Grinstead, UK
Using PSP 8 & PSP 2018 under Win 10
MarkZ
ram: 8 GB
Hard_Drive_Capacity: 500 GB
Re: TGA puzzle
Post by MarkZ »
Terry:
PSP X6 seems to handle this file correctly. How does it look if you place a coloured layer under the TGA you opened?
Mark
Grazie
motherboard: Asus TUF X299 MK 2
processor: Intel Core i9 10900X s2066
ram: 64gb
Video Card: EVGA RTX 3080 XC3 Ultra 10GB
Re: TGA puzzle
Post by Grazie »
Terry, your TGA Transparency is working in Corel PSPX6.
Top Layer your TGA
Next is my Vector Text
Lowest Layer is a blownup Flower . . .
MosaicOval Showing Transparency.png (149.05 KiB) Viewed 1937 times
Grazie
ram: 64gb
Re: TGA puzzle
Post by Grazie »
Are your Background set to WHITE as Default and not Transparent?
G
terrypin
ram: 32 GB
Re: TGA puzzle
Post by terrypin »
Thanks both, appreciate your help.
After further research I discovered that I apparently first need to use Selections > Load/Save Selection > Load Selection From Alpha Channel. That gives me this:
I'm not sure why that's necessary, because without that step I wouldn't see anything useful to help me work with the file. Promoting the original 'Background' to a layer and then placing a solid colour layer below it made no difference. Nor am I clear what I would typically do next after loading that 'selection'. It seems a lot more intuitive to use PNG files with alpha channel transparency, so you can then see the various areas of opacity.
The context is that these TGA files are inbuilt resources used by my video editor, Magix Movie Edit Pro 2014. I'm experimenting with them to better understand how they create their respective effects.
I've uploaded two more:
https://dl.dropboxusercontent.com/u/401 ... lloon3.tga
https://dl.dropboxusercontent.com/u/401 ... culars.tga
On inspection I assume this first one gets its transparency from the pure white background, while the balloons are 254,254,254.
The second looks all black on first opening and like this after the load operation:
