Batch Resize Results in Different Size Image than Script
ltjost
motherboard: Dell Inc. 0Y536R A15
processor: 2.53 gigahertz Intel Core2 Duo 64 kilobyte primary
ram: 8 gb
Video Card: ATI Mobility Radeon HD 4670
sound_card: AMD High Definition Audio Device
Hard_Drive_Capacity: 750GB
Monitor/Display Make & Model: Generic PnP Monitor
Post by ltjost »
I was resizing some jpg images and found that my script resizes files differently than running the resize script manually.
1) I recorded a script that resized to 80% original.
2) I tested a Manual Resize using that script:
2a) I opened an 18 MB jpg file and clicked the "run" icon on the 80% resize script that was saved.
2b) I saved the result as jpg. --- It is 6.5 MB
3) I tested a Batch Resize using that same script:
3a) Open the Batch menu item and selected the 18 MB original file and the same 80% resize script used above,
3b) I ran the batch
3c) I checked the resultant file and find it is only 1 MB (compared to 6 MB if I ru nthe same script outside of a batch process)
Why?
Note that the pixel dimensions are the same for both results.
Here's the script detail that I used in both of these tests:
from PSPApp import *
def ScriptProperties():
return {
'Author': u'',
'Copyright': u'',
'Description': u'',
'Host': u'PaintShop Pro',
'Host Version': u'16.00'
def Do(Environment):
# EnableOptimizedScriptUndo
App.Do( Environment, 'EnableOptimizedScriptUndo', {
'GeneralSettings': {
'ExecutionMode': App.Constants.ExecutionMode.Default,
'AutoActionMode': App.Constants.AutoActionMode.Match,
'Version': ((16,0,0),1)
# Resize
App.Do( Environment, 'Resize', {
'AspectRatio': 1.50554,
'CurrentDimensionUnits': App.Constants.UnitsOfMeasure.Percent,
'CurrentResolutionUnits': App.Constants.ResolutionUnits.PixelsPerIn,
'Height': 80,
'MaintainAspectRatio': True,
'Resample': True,
'ResampleType': App.Constants.ResampleType.Bicubic,
'ResizeAllLayers': True,
'Resolution': 300,
'Width': 80,
'SharpnessValue': 50,
'AdvancedMode': False,
'DialogPlacement': {
'ShowMaximized': False,
'Rect': ((682,271), 489, 428)
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Batch Resize Results in Different Size Image than Script
Post by LeviFiction »
It's not your script, it's the save settings inside the batch process dialog.
Inside the Batch Process dialog Select "Save as new type," then next to the file type JPG select the Options button. Set the compression rate.
If you don't set the compression rate, or if you save over the original, X6 will save with a compression of about 20. Making it as small as possible.
ltjost
ram: 8 gb
Post by ltjost »
Thank you!
