OK, I've done some more research and what I've found is not pleasing. Unfortunately, the RAW files and their derivatives involved are too big to post on a forum so, unless you duplicate what I did, you will have to take my word for my findings. Unless mentioned otherwise, n-bit in the following refers to per channel, e.g. an 8-bit RGB totals 24-bit or a 16-bit aRGB totals 64-bit
Phase 1
1a. I downloaded a virgin 12-bit NEF file into ViewNX 2 using default settings and converted it into a 16-bit uncompressed RGB TIF file
1b. I downloaded the same 12-bit NEF file into ViewNX 2 using default settings and converted it into an 8-bit uncompressed RGB TIF file
1c. I downloaded the same 12-bit NEF file into Paintshop Pro (PSP) Camera RAW Lab using default settings and converted it into an uncompressed RGB TIF file (no choice of bit size)
1d.
Comment: I carefully examined the same part of the three images in their RAW state (before conversion) at 400% (the max allowed by ViewNX 2).
1a and 1b were identical, of course, and high quality. 1c was distinctly and visibly poorer in quality with larger pixels.
Phase 2
2a. I Opened the TIF 1a file into the PSP Editor
2b. I Opened the TIF 1b file into the PSP Editor
2c. I Opened the TIF 1c file into the PSP Editor
2d.
Comment: I carefully examined the same part of the three images, as in Phase 1, in the Editor at 500% and, using the Tabs, was able to switch between them to get direct comparisons.
To my total surprise, 2a and 2b were rigourously identical! In other words, the 16-bit file was converted in the editor to an 8-bit image, similar to 1b, which was poorer in quality than I expected, similar to 1a. Clicking on Image Properties, this confirmed that 2a was 8-bit. Disappointingly, high-resolution pixel corrections were therefore impossible. 2c was similar to 1c, poorer than both 2a and 2b.
Phase 3
3a. I did a few identical edits (Straighten, Crop, Duplicate layer, Resize and Brightness) to each of 2b and 2c, with a Save between each edit (it was deemed useless on 2a, being identical to 2b).
3b.
Comment: At 1:1 frame size, the images were still good.
Zoomed at 500%, the images had considerable pixel-shifts from the originals and 'pixel-clusters round a small or large artefact appeared totally different in size and gradation. One edge line of an object increased from an average three pixels between solid dark to solid light to five pixels on 2b. On 2c, it was more difficult to judge as it varied up to about 5 or 6 on 'before' and was worse on 'after', but almost impossible to put a figure on, as it was more random from the start. I then put the two images 3b and 3c on a full screen viewer. 3b showed a satisfactory image, looking acceptably sharp but 3c was visibly less distinct on careful examination. I guess that printed to A4 quality photo-paper at best, you would probably be hard-put to tell the difference but you probably could on A3 scale.
3c.
Comment:
In the editing in 3a at every save, I got the following message. The "24 bit depth" refers to 8-bit RGB. It would seem that PSP is paranoid about 16-bit TIF files or obsessive about 8-bit ones.
Conclusion: I'm not sure that PSP is the best choice at handling RAW and derivative uncompressed files. One can ask what the purpose is to shoot in RAW (or, in my case, NEF) format, if it can't be edited with as few losses and artefacts as possible? Note that what I have said applies only to the combination of NEF and TIF formats; other formats may be better or worse or just the same - this must be tested before being categorical.
