Batch Rename
kelann162
Batch Rename
Post by kelann162 »
delete
Forriner
motherboard: ASUS Z170M-PLUS
processor: Intel Core i5-6400
ram: 16 GB
Hard_Drive_Capacity: 1250 GB
Monitor/Display Make & Model: Philips Brilliance 272b 2560 × 1440
Corel programs: PSP 2023
Re: Batch Rename
Post by Forriner »
Menu File/Batch rename should work.
kelann162
Re: Batch Rename
Post by kelann162 »
Forriner wrote:Menu File/Batch rename should work.
So this works for you? I have to click File/batch rename, then the list of pics. I have to click modify, then custom text, then type in the new text and click start. Then I get an error. I'm using paintshop pro 6. Says it cannot rename not matter what name I pic.
What am I doing wrong?
right now i use psp to edit pics and picasa to batch rename and tag but it's a pain switching between the 2 programs. Would be nice if I could just use psp. I don't see a way to batch tag a bunch of photos or even one photo either.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: Batch Rename
Post by hartpaul »
Batch rename is a pita in PSP. I have been and only use Irfanview for this. It is a small program and very speedy.
You can find a brief illustrated tutorial here:
http://www.hartpaul.com.au/IRFANVIEW/batchrename.htm
Forriner
ram: 16 GB
Re: Batch Rename
Post by Forriner »
"...then custom text, then type in the new text and click start." If this is EXACTLY what you do, PSP attempts to rename all the selected files to "Custom Text".
You need to provide a unique identifier along with the custom text, like a sequence number, the time, the original document name, whatever, so there is no conflict/doubles in new names.
Cassel
ram: 16Gb
Corel programs: PSP 8 (JASC) to PSP 2023
Re: Batch Rename
Post by Cassel »
I use the Batch process for resizing AND renaming at the same time, so I can rename the resized image with an identifier but keep the original intact. It works fine for me.
Also what is the exact error you are given? This will help find the culprit and the solution.
Cassel
https://scrapbookcampus.com
rkeesecker
motherboard: Dell 0DF42J A00
processor: Intel Core i7-8700 CPU 3-20GHz 3-19 GHz
Video Card: NVIDIA GeForce GTX 1050 Ti
Hard_Drive_Capacity: 1TB
Monitor/Display Make & Model: Insignia 32DR310NA17 [Monitor]
Corel programs: PaintShop Pro 2021
Re: Batch Rename
Post by rkeesecker »
hartpaul wrote:Batch rename is a pita in PSP. I have been and only use Irfanview for this. It is a small program and very speedy.
You got that right. I figured out how to do it, but it still (was an issue posted in these forums way back in 2008) does not allow sequential renaming based on the date taken EXIF data. If there is a way to submit a feature request, I'll do it. And hey, thanks for the link to your tutorial on using the IRFANVIEW batch rename process.
