Ken
The amphitheatre is just outside Denver Colorado - known as red rocks amphitheatre because of the two huge red rocks which form a natural funnel for the sound. As you can see hundreds of locals use it as a keep fit centre running along the rows of seats from side to side working their way up or down after each row depending on their whim. If you are a real keep fit fanatic you also run from bottom to top up quite steep steps.
The zipped package is what I uploaded in the early days of beta testing when Smartsound kept causing a crash
fingers crossed Trevor !
VS X7 stops working - Customise Motion
Re: VS X7 stops working - Customise Motion
Spoke too soon, VS X7 32 bit wont start, splash screen scrolls then disappears as does the Vstudio from task manager.
Reset program to factory default, that removed the library, VS opened ok.
However I can no longer Import Library, so don’t understand why it allowed that last night.
Anyway the program is working ok with no problems with Customise Motion.
I did use the Cleanup.exe file to uninstall, maybe that cleared the registry, I may re-install 64 bit again to see if the Motion error re-appears.
All takes time?
All takes time?
Hi Guys
I think I have found the reason why the program crashed, Smart Proxy files.
I had set Smart Proxy to use Mpeg2 type files rather than those recommended by the program, mpeg2 files being much smaller than standard proxy files and were quicker to create.
But it does seem as though that is causing the problems.
And yes I used Mpeg proxy with 32 bit and that worked ok???
If you wish you can test this yourselves by changing the proxy settings, create a mpeg proxy file then apply Customise Motion.
I guess its something to remember
