Artifacts/Outline when resizing transparent layers - X6
DeltaAlphaBravo
Post by DeltaAlphaBravo »
Hello,
I'm getting an unwanted effect whenever I resizing an image that has layers with transparency. Upon resizing an image; any layers with transparency gets nasty looking outline around whatever is in it.
I'm not a professional so forgive my ignorance. I don't know the jargon to help describe what's happening. the best way is by showing you screenshot of what I'm seeing:
Here's a image with a white (#ffffff) background layer. It has another transparent layer on top. In this layer I have put white text "hello world" and hand drawn three white dots.
As expected: all you can see it a white image. You can't make out where the text and dots are because they are the same colour as the background.
I then shrink the image using 'Image->Resize'. Afterwards I see this (using all resamples apart from pixel resize):
You can clearly see the text and dots because they have been outlined.
I used the example above to reproduce what I am seeing. But this outline appears if the background is transparent too. Or if it's a different colour.
What am I doing wrong? How can I stop this unwanted outline?
Thanks in advanced
-Dan
If it matters:
Paintshop Pro X6
Windows 7 Home
Intel i7 3930K
16GB RAM
Nvidia 780GTX
LindaSue
motherboard: Gigabyte
processor: 2.71GHz AMD Athlon II X2 215 processor
ram: 3 GB
Video Card: ATI Radeon HD 4350
sound_card: Realtek AC97 Audio [onboard]
Hard_Drive_Capacity: 1320 GB
Monitor/Display Make & Model: Asus MX279 HDMI 27-inch
Corel programs: Paint Shop Pro X2, X4, X6
Re: Artifacts/Outline when resizing transparent layers - X6
Post by LindaSue »
I just tried it and got the same result that you did.
X6 Test.jpg (19.8 KiB) Viewed 3264 times
I also tried it in PSP8 and got no outline.
Using Paint Shop Pro versions 5, 6, 7, 8, 9, 12, 14, 16
LindaSue
ram: 3 GB
Post by LindaSue »
I got this in X4:
X4 test.jpg (7.08 KiB) Viewed 3263 times
LindaSue
ram: 3 GB
Post by LindaSue »
And in X2:
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Post by hartpaul »
I have found that if you modify your selection by 1 pixel (600 x600 image with text 96 pixels) then the effect disappears.
