Import frames from previous versions
thelrose
Hard_Drive_Capacity: Select One
Post by thelrose »
How do I import frames and borders from previous versions. I cannot find where these files are even located in psp x6.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Re: Import frames from previous versions
Post by LeviFiction »
You should be able to just copy them into the necessary folders.
To find the folders for each type go to File -> Preferences -> File Locations
In the dialog you can select which type you want, and you can add an existing folder to the list of folders to look through, or you can just locate the folder that PSP is looking in.
thelrose
Post by thelrose »
Where should I be to go to File= preferences, file locations. Should I be in PSP
ram: 6 GB
Yes inside PSP.
brucet
operating_system: Windows 8.1
Post by brucet »
I found that x6 didn't like the location of my locations! So to overcome that I simply found the old Frames and copied and pasted them into the x6 location.
regards
trueblue
Moderator
motherboard: ASUS Z97M Plus
processor: Intel Core i7-4790 CPU 3.60 GHz
ram: 12GB
Video Card: NVIDIA GeForce GTX 750
sound_card: NVIDIA High Def Audio Realtek High Def
Hard_Drive_Capacity: 1.740GB
Monitor/Display Make & Model: Benq E2420HD 24" wide x 2 monitors
Corel programs: PSPX8-VideoStudio-AfterShot
Post by trueblue »
Go to your previous versions Picture Frame folder. Copy all the files within the folder.
Go to (win 8.1) Documents / Corel PaintShop Pro / 16 / Picture Frames and paste the files in this folder.
Next go to File, File Locations. Look at the list in the left panel for Picture Frames.
In the middle panel - Picture Frame file folders. Ensure your ...... / Documents / Corel PaintShop Pro / 16 / Picture Frames is visible. If it isn't, click on Add, locate the folder and click Ok.
You maybe interested in joining the PSP Beginner's Workshop where you will learn all the basics of PSP. The link is above in the Beginner's Workshop thread.
~~~~Maureen~~~~
Creative-Designs
Free! PaintShop Pro Tutorials
