Constantly hangs on bulk operations
Bugs & Suggestions
lenscape
operating_system: Linux
System_Drive: N/A
motherboard: Multiple
processor: Multiple
ram: Varies
Video Card: nVidia Corporation generally
sound_card: Varies
Hard_Drive_Capacity: 15TB+
Monitor/Display Make & Model: Multiple
Corel programs: Aftershot Pro 2
Post by lenscape »
This is an nice simple example but by no means the only way to provoke the problem.
1. Apply Perfectly Clear to an image.
2. Selectively copy (shift-ctrl-C) just the Perfectly Clear setting
3. Paste to all other images in directory (anything over 50 images should do)
Result is a hang.
Many bulk operations end up the same including imports.
The way to overcome this is to set the "CPU threads" limit to 1 in performance settings.
Now, I purchased a chunky 6 processor system (12 logical processors with Hyperthreading) to take advantage of Bibble's (as it was then) multiprocessing capabilities and I'm somewhat disappointed that after years of development this software still fails to fulfil its promise. I'm forced to cripple ASP to make it work properly.
I'm a full-time professional photographer and I've chosen to depend on Linux and a general open source workflow. Bibble/ASP is the only closed source software I use and it sticks out for its unreliability. The software written by keen, enthusiastic and generally unpaid programmers trumps it completely for stability and dependability.
Responses and commitment, Corel?
System: ASP 1.2.0.7. OpenSuse 13.1
afx
System_Drive: N/A
Video Card: FirePro 4900
Re: Constantly hangs on bulk operations
Post by afx »
OpenCL active or not?
cheers
afx
lenscape
System_Drive: N/A
processor: Multiple
ram: Varies
sound_card: Varies
Post by lenscape »
afx wrote:OpenCL active or not?
cheers
afx
No. Not available on my configuration.
lenscape
System_Drive: N/A
processor: Multiple
ram: Varies
sound_card: Varies
Post by lenscape »
Is that the limit of the support for this issue?
afx
System_Drive: N/A
Post by afx »
Since when is there support or answers from Corel in this forum?
cheers
afx
ferdinand-paris
motherboard: GA-X58A-UD3R
processor: 3.20 gigahertz Intel Core i7 960
ram: 4Gb
Video Card: NVIDIA GeForce 7300 GS
sound_card: Realtek High Definition Audio on-board
Hard_Drive_Capacity: 2500 Gb
Monitor/Display Make & Model: Eizo CG222W
Post by ferdinand-paris »
This is a user-to-user forum. Occasionally Corel staff will say something, but I've not seen them use this forum to provide support.
lenscape
System_Drive: N/A
processor: Multiple
ram: Varies
sound_card: Varies
Post by lenscape »
This is a "Bugs & Suggestions" forum.
Now, I can see that a "Help and Support" forum could be provided by peers but it is entirely pointless to offer suggestions and bug reports to the rest of the user community. Where would that get anyone?
If Corel can't do something useful with ASP, then it's about time they opened the source and let the community take it over. Is wilful neglect of software a crime yet?
It's tragic that something so nearly great is bumbling along as an almost OK offering.
As an aside, I'm here because I'm waiting for ASP to delete some master versions from the library. It stumbles through deleting them at the rate of about one every 30 seconds. I'm deleting over 50. It must be quite a challenge to make it so slow.
I might go out for a walk.
