Changing Font on Multiple Titles
I created a project with Video Studio X6 and used titles in between the pictures to add additional information. I would like to change the font on all the titles to a different font. Is there a way to change them all at the same time or do I have to go into each title and change them manually?
Re: Changing Font on Multiple Titles
Highlight the text on your first title and change the font to whatever you like - RIGHT click over the text block in the timeline and choose "copy attributes".
Now left click on the second text block in your timeline so it shows selected - now go to the last text block in your time line but this time hold down 'shift' as you click on it (standard windows multi-select procedure) - all text blocks are now selected - right click over them and choose "paste all attributes" - all titles should now show your new font.
Thanks for the help. I was able to highlight all the titles in the timeline however after I click on paste attributes the font does not change. I have the titles in the video track timeline. Does that make a difference?
if you have the titles in the video track with videos between them it does not work.
best you can do there is change the first one - copy attributes then right click each title individually and paste all attributes one at a time.
