hello all I have a video file with these specifications ,when I trimmed this video and convert it to avi the audio doesn't match the video ,is there any solution for this problem please
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format_Settings_GOP : M=1, N=16
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 48mn 27s
Bit rate mode : Variable
Bit rate : 1 800 Kbps
Width : 960 pixels
Height : 544 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.115
Stream size : 625 MiB (92%)
Writing library : x264 core 107
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 48mn 26s
Bit rate : 152 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 44.1 KHz
Stream size : 52.7 MiB (8%)
audio and video dont match
haytham501
Re: audio and video dont match
The only way may be to split the audio and manually re-sync it - then render a new video.
Is the out of sync constant throughout - in which case you could just slide the sound block slightly
or does the amount of sync change throughout the video - in which case you may have to stretch (or contract) the sound track slightly to match.
It would also be very useful to know which flavour of .avi you were converting it to, and with what properties. You may not be aware that there are over 800 different (quite different) types of video which use the .avi extension. It is just a wrapper extension, apart from the original uncompressed .avi which is huge in size: one hour of video in it takes around 65 GB -- yes, that GB, not MB or KB.... And down from that are various degrees of compression.
I note that your original video is called avc but has a bitrate of only 1800 kbps, which tends to be very low so I assume it was not high def video. But where did it come from in the first place?
With this sort of information we might be able to suggest a better way of rendering which might avoid the out of syn audio and video...
