video editing
ottersea
motherboard: Biostar
processor: Intel duo core
ram: 2gig
Video Card: Nvidia GForce 8400
Hard_Drive_Capacity: 1.7 TBytes
Monitor/Display Make & Model: Viewsonic VA2431
video editing
Post by ottersea »
I am using X4 and am wondering if there is some way to edit a video in this version. I have a video that has a message at the bottom of the video that I would like to edit out. Is there some way of doing this?
Thanks.
Re: video editing
The only practical way of doing that is to use the Crop filter -- which will of course mean you lose the bottom portion of your video.
ottersea
ram: 2gig
Re: video editing
Post by ottersea »
I found the cropping filter but have not been able to figure out how it works. I click on it and it just puts a balloon in the preview window that expands out on all 4 sides. How does one get this into the video clip?
Re: video editing
Post by BrianCee »
Put your video in the video track - drag the cropping filter from it's library pane down onto the video.
open the options panel by clicking on the blue "Options" tab which is just above the right hand end of the timeline
In the options panel click on "Customise Filter"
A new panel will open where you can set the size and position of the crop rectangle.
You need to set the beginning and end parameters by selecting the little red diamond on the timeline there - these signify "Key Frames" and you can add more if you wish so that the crop area can change size and position throughout your video if that is what you want .
Click to UN-check the box next to "Fill color" at the bottom - then click OK and you should see the result.
