PSP X6 and X5 Vector problem
JudyM
processor: 3.40 gigahertz Intel Core i5-4670
ram: 2048 MB
Hard_Drive_Capacity: 999.36 GB
Monitor/Display Make & Model: HP L1706
Corel programs: PSP 9,X, X4 - 2018
Post by JudyM »
I recently downloaded and have been using Gary Barton's nifty script, Vector Stroke...available from Pixelnook.
This script works with many of the tools, brushes of various sorts , tubes and even the Art media tools to follow a vector path.
It works a little differently from Vector Tube and Vector Paint in that you create a path and whilst that path is selected [not the whole vector layer], you create a new raster or art media layer and start the script.
It works beautifully in versions 9 to X3 [ and maybe x4 ??] but I am unable to keep that path selected in either X5 or X6 without using CTL and then the whole vector layer is selected which gives a really horrid result with the art media tools.
Is there a work around?
In [a href="https://plus.google.com/photos/11519953 ... 5iCueOshwE" ]this album[/a]
1 Image from PSP 9
2 image from X6
3 An example of what I want to create ..in this case using the marker pen.
Judy
trueblue
Moderator
motherboard: ASUS Z97M Plus
processor: Intel Core i7-4790 CPU 3.60 GHz
ram: 12GB
Video Card: NVIDIA GeForce GTX 750
sound_card: NVIDIA High Def Audio Realtek High Def
Hard_Drive_Capacity: 1.740GB
Monitor/Display Make & Model: Benq E2420HD 24" wide x 2 monitors
Corel programs: PSPX8-VideoStudio-AfterShot
Re: PSP X6 and X5 Vector problem
Post by trueblue »
I ran the script in PSPX6 and it works perfectly. Lower the brush size.
~~~~Maureen~~~~
Creative-Designs
Free! PaintShop Pro Tutorials
JudyM
ram: 2048 MB
Post by JudyM »
Maureen
Which art media brushes did you use?
My result is just a pattern of dots :(
Judy
trueblue
Moderator
ram: 12GB
Post by trueblue »
I tried all Art Media brushes.
I drew a line on a vector layer.
I then selected the oil brush. Set the Vector Paint script to go and the stroke covers the vector line, but on it's own Art Media Layer.
I drew another line on the vector layer but this time chose the watercolour brush and a different colour.
It worked the same way on the wavy line with the marker tool.
Before you run the script. After selecting the brush go to Presets and reset to default then try again.
~~~~Maureen~~~~
Creative-Designs
JudyM
ram: 2048 MB
Post by JudyM »
Thanks Maureen
I did get them to work using your directions..but only with default settings....which is very limiting of course. :(
I also ended up with a spray of spare pixels unfortunately...particularly along the edges of the brush stroke and at the end of the oil brush.
[img][img%20src="https://lh6.googleusercontent.com/-o3xm ... +brush.jpg"][/img]
Luckily the script works beautifully in earlier versions of PSP . :)
Judy
