How to use titles in VS Pro 4 from an earlier VS version
Mikell
- processor: 2.60 gigahertz AMD Athlon 64 X2 Dual Core
- ram: 3072 Meg
- Video Card: NVIDIA GeForce 210 [Display adapter]
- Hard_Drive_Capacity: 160 GB
- Monitor/Display Make & Model: DELL 1704FPV
A few years back I upgraded from Corel VideoStudio 12 to VideoStudio Pro 4. I like the titles in VS 12 Better Than titles in VS Pro 4. Is it possible to use titles from VS 12 while working in VS Pro 4? Can someone tell me how this can be done if it's possible? Pro 4 gives the option of adding another folder when using titles but I don't know how to go about doing that.
Re: How to use titles in VS Pro 4 from an earlier VS version
The easiest way to do that is to open up VS X2 and drag the titles you want down into the title track - then save that project as a .vsp (called titles for instance)
Then close X2 and open up X4 - in X4 open up your project "titles" and drag the titles up into the existing titles library.
you can do the same sort of thing with other items like images. colour blocks and music etc.
Mikell
- ram: 3072 Meg
Thanks very much Brian, that worked real easy to transfer titles to my pro 4 program. I will use that method on other items as well.
