I just purchased PictureShow 3 Deluxe last month and finally have figured out most of its features. I assumed I got Photo Explorer 5.0 with the purchase (the manual was enclosed in the box). However, no Photo Explorer 5.0. I received the program disc and a Bonus CD (with "clip art"). Is there a separate disc for Photo Explorer??? Or am I just overlooking it and it is on the Program disc for PictureShow.
Thanks!
Photo Explorer missing?
keenart
Check to see if the Photo Explorer is on your Start menu under Programs one of the additional programs listed in the Ulead PhotoShow Folder. If it is listed it should be installed; just click on the program name and it should load.
You can also go to the Contol Panel and click on Add\Remove Programs to see if Photo Explorer is installed.
The program may have become damaged or during installation you did not select, or unchecked the box to install Photo Explorer. If so you can Repair your installation and reinstall additional components in the Add\Remove feature.
jomay
Photo Explorer Missing
Thank you! I went to Control Panel (Add/Remove feature) and re-installed. Not sure what happened on initial installation though. Appreciate the help!
