PSPx6 Level Image Issue
Patman
motherboard: Alienware 04vwf2a02
processor: 2.67ghz Intel Core i7 920
ram: 12280
Video Card: AMD Radeon 5800 Series
sound_card: AMD HiDef Audio Device Realtek HiDef Audio
Hard_Drive_Capacity: 5992gb
Monitor/Display Make & Model: Visio 550
Post by Patman »
I did not have this issue with PSPx4. The issue showed up in PSPx6. When I level out an image in the "Edit" section there are regions on the left and right side of the image that do not move with the leveling
adjustment. The image then looks broken as counter-tops or sidewalks or any straight edge look as if the image has been separated from itself. I have downloaded PSPx6's updates but have had no relief and have seen no discussions on this topic.
Suggestions? Thanks!
Re: PSPx6 Level Image Issue
Welcome to the forums Patman,
When using the level tool, do you have the crop image box checked? By your description it would appear that it is rotating/leveling without cropping, thus you're seeing the workspace behind your image.
Image leveled without cropping
Check the box Crop Image
Image leveled with the Crop Image box checked
Grazie
motherboard: Asus TUF X299 MK 2
processor: Intel Core i9 10900X s2066
ram: 64gb
Video Card: EVGA RTX 3080 XC3 Ultra 10GB
Post by Grazie »
Correct Info from Ron P.
What you're looking at is the BACKGROUND plate of X6. If you'd set it to Transparent you'd be looking at CHEQUERS and you'd have had a fit!e
Grazie
