cross fading photos
samsara
cross fading photos
Post by samsara »
I'm creating a rather long video and want to avoid transitions that I'm told, take up mgs. I thought you could just run two photos into one and other and they'd crossfade. Is the a way to make a quick transition between photos without the sudden jump from one to the other (without using transitions)?
Re: cross fading photos
Post by BrianCee »
a crossfade between two photos requires a crossfade transition - unless you fade one out and fade the next in - that would give a blank screen in the middle though no matter how short it was it would show,.
I don't know where you heard this story about transitions using up memory - they use almost nothing - in any case you either need a good looking show or you don't - if you do then use various transitions between photos.
As you are using photos they need much less file space than a video so you will be able to get a few hundred photos with transitions onto a standard DVD.
If you insert a photo into the timeline and then insert another after it -- and if in Preferences > Edit you haven't selected to automatically insert a transition -- then you can simply drag thestart of the second photo back over the end of the first photo, and you will have a crossfade between the images. The duration of the cross fade, moreover, will depend on how far you drag the second image over the first.
But like Brian, I agree that it is nonsense to suggest that using transitions uses up lots of space.
Just adding to Ken's advise,
You need to set Crossfade as the default transition in Preferences. If not the default set by Corel is Random.
Of course, it's Random if you select to automatically insert a transition but don't specify which. But my point was that without selecting either automatic insert or a specific transition, if you put two photos -- or of course videos -- into the timeline and drag one over the other, a crossfade is automatically made with a duration corresponding to the width of the overlap.
Post by BrianCee »
Sorry Ken - but in my versions of VideoStudio the transition applied if you forcibly overlap clips is the transition specified in preferences at the bottom of the edit tab - even if you do NOT select to "Automatically add transition effect" - it is not always the crossfade
Ah had! I see you are correct. It's just that I use the crossfade nearly 100% of the time, so that is usually what is set when I select automatically insert transition. So when I unticked that box, Crossfade remains. I just changed it to something else, and that new transition appeared when I overlapped the photos.
Love this forum: you learn something new every day!! :oops: :lol:
