Watermark Option has Disappeared - Help
The Watermarking option has disappeared from under my "image" menu... Any ideas on how to get it back? Sheesh!!! Any help would be appreciated!
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Re: Watermark Option has Disappeared - Help
Quickest way would be to reset the Workspace. But if you've made lots of changes that will reset everything.
Other way is to use the Customize dialog to put it back in.
- To reset the workspace close PSP. Then while holding "SHIFT" double click on the PSP icon. It'll ask if you want to reset the UI to factory defaults.
To use the customize dialog
1) Open the customize dialog - View -> Customize
2) Along the left hand side "Categories" select "Image"
3) On the right-hand side at the bottom of the list you'll see the three Watermark options.
4) Leave the Customize dialog open, click on the Image menu to open it.
5) Drag the Watermark commands into the Image menu.
If you want the commands to be under the Watermarking sub-menu instead of directly in the Image menu
Select "New menu" from the left side Categories list. Then Drag the "New Menu" option from the right-side into the Image menu list.
You can right-click on the new menu option to change how it looks, the text and so on.
You can then drag the Watermark commands into this submenu.
