Greetings. I'm using Corel VideoStudio Pro X6.
Can anyone advise if it is possible to copy and save a split audio as a separate mp3 file? That is, I split the audio from a video file in VS X6, and I want to copy it, enhance it and save it as a separate mp3 file for playback (for example in Windows Media Player).
Thanks,
Richard
copy split audio as a separate mp3 file?
Re: copy split audio as a separate mp3 file?
Not as an mp3 - but as a .wav or .wma which you could then convert to mp3 although wav and wma will also play in Windows Media player.
No need to split the audio first - just put the video in the timeline then go to "Share >> Create Sound File" - choose output location, name and format and "Save" the sound track you want. Will also work if you have already split the audio,
brinoto
- processor: Intel I7 2600 3.4 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 1.5TB
Thanks very much Brian. Quite simple - there is so much in the program to find and learn.
