When I try to enter vector text on a .pspimage, the first few characters don't appear. If I look at the vector layer only, they are there, but if I make the background visible as well, they disappear. Also, it seems vey difficult to select the text for editing (i.e. greyed, instead of in a selection box).
Please advise.
PSP x6: entering vector text, characters are hidden
Joelle
- motherboard: Asus Prime B350M-A
- processor: AMD Ryzen 5 1500 Quad-Core
- ram: 16 GB RAM
- Video Card: NVidia GeForce GTX 1050
- Hard_Drive_Capacity: 1TB
- Monitor/Display Make & Model: Samsung
- Corel programs: PaintShop Pro X9
Re: PSP x6: entering vector text, characters are hidden
Silly question, but have you got the text layer above the image layer?JMW1937 wrote:When I try to enter vector text on a .pspimage, the first few characters don't appear. If I look at the vector layer only, they are there, but if I make the background visible as well, they disappear. Also, it seems vey difficult to select the text for editing (i.e. greyed, instead of in a selection box).
Please advise.
it makes no difference if the image is a .pspimage of anything else, the text is on it's own layer
Also look at the Help Files under Text, creating text.
To edit the text, open the vector layer, click on the tiny triangle to show the text layer.
Double click on the text layer, which will generate the cursor on the text itself, from there you can delete or whatever.
Using the Text Tool takes a bit of getting used to, but it works ok, although I miss the old text box.
Joelle
Joëlle
(PSPX9 )
(PSPX9 )
MarkZ
- motherboard: Intel DQ67SW desktop
- processor: Intel Core i7 i7-2600 3.40 GHz
- ram: 8 GB
- Hard_Drive_Capacity: 500 GB
- Monitor/Display Make & Model: LG Flatron E2241
- Corel programs: PSP 2018 X9 X8 X7 X6 ASP3 ASP
JMW:
If Joelle's suggestions don't solve the problem and you are using PSP X6, the fact you don't see the first few characters could be due to a bug in the program. If you are zoomed in on the text the program seems to be slow in redrawing. I have found that if I zoom out the characters appear and I can then zoom back in to continue what I was doing. It was very disconcerting at first.When I try to enter vector text on a .pspimage, the first few characters don't appear
Mark
- Tony Lenton
- motherboard: Intel DH55TC
- processor: Intel Core i5 3.20 GHz
- ram: 12GB
- Video Card: GeForce GTX 1060
- sound_card: On board Realtek High Def Audio
- Hard_Drive_Capacity: 4500 GB
- Monitor/Display Make & Model: Lenovo S27i
- Corel programs: PSP X6 PSP2020
And if you want the "old" style text box...
To Add text in a box hold down the Shift key while clicking and to Edit text again hold the Shift key when the [T] symbol appears and click.
JMW1937
- motherboard: Dell 0W2562
- processor: Pentium 4 2.6 GHz
- ram: 2560 MB
- Video Card: GeForce FX5200
- sound_card: SB Audigy 2
- Hard_Drive_Capacity: 580 GB
- Monitor/Display Make & Model: Samsung SMB2230H
Thank you for this help. I will try out the fixes as soon as possible.
