Lip Sync Problem
kevinreddog
OOS Problems
Post by kevinreddog »
This is the latest from Ulead Support on OOS problems: The bad news is that the links didn't work.
Could you please try the following steps. I hope this helps.
[Steps]
1) Clean up temp files from\Start menu\Programs\Accessories\System Tools\Disk
Cleanup.
2) Uninstall VideoStudio 8 from control panel Add/Remove programs
3) Delete following folders
=>C:\Documents and Settings\All Users\Application Data\Ulead Systems\Ulead
VideoStudio
=>C:\Documents and Settings\All Users\Application Data\SmartSound Software Inc
=>C:\Documents and Settings\[Username]\My Documents\Ulead VideoStudio
=>C:\Program Files\Common Files\Ulead Systems\
4) Reinstall VideoStudio 8 again
5) Install the latest VS8 patch that you can download here:
ftp://ftp.ulead.com/pub/updates/videost ... tch1_e.exe
Be sure that DMA is enabled for IDE hard disks.
1. Control Panel: System: Hardware tab: Device Manager.
2. Click "IDE ATA/ATAPI controllers"
3. Double click on Primary IDE Channel: Advanced settings.
4. Be sure Current transfer mode is DMA. (Transfer mode should be DMA if
available in default.)
Download the latest version of DirectX and other necessary updates from
Microsoft:
http://windowsupdate.microsoft.com/
Can you please try the following suggestions:
1) Defragement HD. If you haven't done defragment for a long time, it's better
to do it before the operation.
2) Please make sure this video file is ok, I suggest you check it.
3) Be sure that there are no other running applications.
If you have some hardware devices that are currently connected via USB port like
compact flash card reader, removable drives, etc., then please just unplug them
and close all running applications like screen saver and memory-resident
applications (system monitor, anti-virus application, etc.) as they may cause
error as well before performing a data write/system conflict.
Download ftp://ftp.ulead.com/Silent/ulcdrdrv/3617246.zip (LATEST version, build
date: July 27, 2004)
Unzip it into C:\Program Files\Common Files\Ulead Systems\DVD directory to
overwrite the original files.
Consider the following before and during burn process:
Please try to use the blank disk of other brand to burn.
Please try lowering the burner's speed to burn.
Choose the 'BURN-Proof disc protection' check box if your burner supports these
features.
If you have any other questions regarding Ulead products, please don't hesitate
to contact us again.
jwarner
Post by jwarner »
If you ftp to: ftp://ftp.ulead.com you'll find one of the files at:
ftp://ftp.ulead.com/pub/Updates/videost ... tch1_e.exe
The other file is not there, in fact, the "Silent" directory is empty...
