Rotopen Filter output is different after editing
robspa48
motherboard: AsusTeK P8B75-M
processor: Intel i7 3770
Video Card: Intel HD Graphics 4000
sound_card: VIA HD Audio
Hard_Drive_Capacity: 2TB+3TB
Corel programs: CVSX9,CVSX10,CVS 2018, CVS 2022 Ultimate
Post by robspa48 »
I have a problem with VS ProX6 Ultimate when using Rotopen Filter to draw a path across a map: effect is perfectly fine when playing the project (i.e. I get the right path animation moving from point A to point B), but result is different after rendering the project: the path is drawn parallel to the original one but shifted to the right side and moved downward.
Any hint why and what should I do to avoid this problem?
Screen capture when playing the project, before rendering
Same after rendering
Roberto
robspa48
Re: Rotopen Filter output is different after editing
Post by robspa48 »
after different trials I found the solution: I had problems only when rendering the project in a format 1920x1080 (AVCHD or BR) whereas I had no problem when rendering as DVD or any other format 720x480.
So, first I rendered just the clip with rotopen filter as a 720x480 format, and then included this rendered clip in my project. When rendering the whole project again as AVCHD, everything was OK.
Hope this is clear and could be of help to others experiencing similar problems..
Roberto
dbz2000
processor: InTel[R] Core [TM] i9 7900X 3.60 Ghz
ram: 16 GB
Video Card: GTX 1070
sound_card: NVIDIA High Definition Audio Device
Hard_Drive_Capacity: 1.5 TB
Monitor/Display Make & Model: Dell ST 2310 Analog
Corel programs: VideoStudio 2018_ VideoStudio Paintshop
Post by dbz2000 »
Thank you for this workaround. I was having the exact same issue and this will be a great solution unless there is something more simple. Thanks again and be well. :D
DBZ2000
"Instead of trying to add years to your life; try adding life to your years"
