PSP Pro X6 missing plugin
Grace
processor: Intel Core 17-3770 CPU
ram: 16.0gb
Hard_Drive_Capacity: 1.81 TB
Monitor/Display Make & Model: ViewSonic
Post by Grace »
When I try to add a picture frame I get the following "unable to load the requested plug-in filter. The plug-in may not be installed properly or missing files (Plugin: PSPFormat64.8bi) Then need to use task manager to shut program down.
hartpaul
ram: 8 Gb
Hard_Drive_Capacity: 1000 Gb
Re: PSP Pro X6 missing plugin
Post by hartpaul »
Do you mean add (import) a picture frame, or in program try to apply one of the normally installed picture frames? Is it all picture frames, or only some frames. Are you using the 64 bit version or the 32 bit version of PSP X6
Grace
ram: 16.0gb
Post by Grace »
I am trying to load one of the normally installed picture frames. None will show up as get the missing plugin message. I am using the 32 bit version as for 64 bit none of my other filters would work at all while they do in 32 bit.
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
Sounds like a corrupted install. Of course I can't find that plugin anywhere on my system anyway. Have you tried uninstalling and re-installing?
Grace
ram: 16.0gb
Post by Grace »
I tried a reinstall and the same but it is odd that if I run the 64 bit the loaded frames will load but not most of my filters and if I run the 32 bit the frames will not load but all of the filters will so looks like it may just be something I need to deal with.
ram: 6 GB
If you just bought PSP you should still have a warranty on it, you should be able to contact support on this issue.
