hello to all
I have a 960*544 mp4 video file and I want to make a template in order I can trim this video
I have corelvideostudio pro x6 and when I choose make movies template manager then new there is no choice for 960*544 frame size and I can not see my video If I choose add from make movies template manager
is there a way to have this template please
can i make a 960*544 mp4 template
haytham501
Re: can i make a 960*544 mp4 template
960 x 540 is 16:9 widescreen ratio so your 544 is pretty close so why not use 16:9
1280 x 720 or 1920 x 1080
We cannot User Define MP4 frame sizes but can do using Mov.
Mov and MP4 are just containers holding the compressors, originally MP4 was developed from Mov so are very similar.
Try QuickTime Mov using MPEG4 Visual as the compressor.
haytham501
thank for your reply but if I use 1280*720 do I have the same quality or not or should I increase the bitrate
Without seeing the actual video I can not say if the quality will be affected, I would expect it to be similar......
You will most likely be changing the compression type and as such alter the bit rate, mov wont give the option of changing the bit rate
There are many compressions to choose from, I only suggested MPEG4 Visual.
You do not give full details of your original video only the frame size???
Have you tried creating new clips using Mov, try a few types to compare time to render against quality.
haytham501
I am converting it to avi in order to have same frame size with mpeg4 visual but I hope that I can find a way to keep the file in mp4
haytham501
General
Complete name : D:\haytham\haytham\01_hd.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 586 MiB
Duration : 42mn 51s
Overall bit rate : 1 912 Kbps
Writing application : Lavf52.32.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format_Settings_GOP : M=1, N=16
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 42mn 51s
Bit rate mode : Variable
Bit rate : 1 800 Kbps
Width : 960 pixels
Height : 544 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 29.970 fps
Minimum frame rate : 8.563 fps
Maximum frame rate : 499.500 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.115
Stream size : 554 MiB (94%)
Writing library : x264 core 107
Format : MPEG-4
Codec ID : isom
File size : 586 MiB
Duration : 42mn 51s
Video
Format : AVC
Codec ID : avc1
Duration : 42mn 51s
Width : 960 pixels
Height : 544 pixels
Resolution : 8 bits
Colorimetry : 4:2:0
haytham501
dear mr Lata this is the information of the file
I want to convert it to avi with same frame size or keep it mp4 but with a frame size of 1280*720
the thing that I concern of is quality
which format should I use avi or mp4 and if I use mp4 what bitrate to put
I think you are best using MPEG4 rather than AVI. Besides avi is just a container holding the compression data of which there are 800ish type?
If you do Share Create Video File –Mpeg4 – there are three options
Try these two to compare quality and time to convert/render your video clips, then compare the files size in Mb
MPEG-4 AVC (1920x1080)
MPEG-4 AVC (1280x720)
AVCHD 1280 x 720 is also of course mpeg-4, though produced using the h.264 codec and not the various other mpeg-4 codecs. You could also make a Custom template for that, choosing MPEG Transport Stream (*.m2t) as the target format, then on the compression tab choose AVCHD as the format, and on the General tab, set 1280 x 720 as the frame size.
In fact, choosing Share > Create Video File > AVCHD, there is already a 1280 x 720p template, but that will give you 60 fps, whereas your video is 29.97 full frames per second, so that is why I suggest a Custom template.
